Random Little Question Thread
Old Oct 19, 2010 | 12:01 PM
  #1231
OKStateG35's Avatar
Originally Posted by IMA-G-RIDER
does your regular turn signal in the headlight work ?
Yep. It really sounds like it has to be the bulbs. I'll check them out at lunch time and see if they look burned.
Old Oct 19, 2010 | 12:18 PM
  #1232
WILLIE BEANS's Avatar
yeah .. lets hope they are both blown ..
Old Oct 19, 2010 | 12:22 PM
  #1233
NFSP G35's Avatar
? = 2B || !2B
Actually....... did you check your blinker fluid?
Old Oct 19, 2010 | 12:56 PM
  #1234
Abax84's Avatar
Can anyone tell me what this piece is under the body in front of the rear wheel? Its only on the passenger side. The small tab you can see coming out from under the car.
It's the small, broken looking tab towards the front of the frame, in case this pic the confuses anyone.
And for fun, a Miata towing a boat
Old Oct 19, 2010 | 01:00 PM
  #1235
NFSP G35's Avatar
? = 2B || !2B
I think it's just a little wind diffuser thing.
Fairly sure there used to be one on each side. Maybe the one on the driver's side got scraped off?
Old Oct 19, 2010 | 01:16 PM
  #1236
Abax84's Avatar
Ill have to go check the other side. Its odd though, the piece that sticks out and is visible, is like a tab stuck up into the body.
Old Oct 19, 2010 | 01:48 PM
  #1237
OKStateG35's Avatar
Yeah man, no dice.
I checked the fuses and all looks good. I pulled the passenger side bulb and it looks fine, but I'll replace them both anyway. I've had bulbs look fine before and replacing them did the trick.
Old Oct 19, 2010 | 01:52 PM
  #1238
OKStateG35's Avatar
Yeah, pretty sure my car has those tabs on both sides. They're so you can get crazy sideways around corners without rolling the car.
Old Oct 19, 2010 | 01:57 PM
  #1239
NFSP G35's Avatar
? = 2B || !2B
^LOL.
I just checked. I have them on both sides.
Still no idea what they're there for
Old Oct 19, 2010 | 02:13 PM
  #1240
Abax84's Avatar
^Yeah, same here. Never noticed it on the drivers side before. Maybe a small guard to deflect debris from the wheels/tires/brakes/suspension?? Pretty weak theory but I can't make sense of them.
Old Oct 19, 2010 | 02:16 PM
  #1241
Hammerhead i-Eagle Thrust's Avatar
does the OEM 350z front strut tower bar fit on our cars? and if not, what is stopping it from fitting?
http://cgi.ebay.com/ebaymotors/03-Ni...#ht_2329wt_927
  #1242
NFSP G35's Avatar
? = 2B || !2B
^No, it doesn't
Old Oct 19, 2010 | 02:18 PM
  #1243
Wannabe6MT's Avatar
-MN G Crew-
Mine has it too.
  #1244
Jeff92se's Avatar
Red Card Crew
anyone reattach their door panel inserts? Mine are peeling off. I have the 3m spray but what's the best way to not getting all over the interior?
Old Oct 19, 2010 | 02:28 PM
  #1245
^No, it doesn't
any idea what is blocking it or does it just not line up?
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
