Random Little Question Thread
Rating: Thread Rating: 7 votes, 5.00 average.
Old Oct 26, 2010 | 02:58 AM
  #1411
3truman's Avatar
Do it! I have the same ones just flat black, I like bronze but couldn't find the right color I wanted
Old Oct 26, 2010 | 09:43 AM
  #1412
WILLIE BEANS's Avatar
Originally Posted by g35studd
Wow that looks great! Thanks!
no problem ..
and its brilliant silver too . but not only were the sides/ front/ rear bottoms painted all around ..
the mirror bases were painted ..
and the side door molding deleted and filled in ..
Old Oct 26, 2010 | 09:46 AM
  #1413
Siaon's Avatar
There are a couple of weird sounds that "seem" to be coming from the bottom of my car (tranny?)
When I accelerate fairly hard, there's grind-like sound that comes from the bottom of the car. It only happens at the lower gears.
And also, if I idle in either Drive or Reverse, there's this sound that sounds like something is loose, but if I put the car into Park or Neutral, the sound disappears (brake pedal pressed).
Any idea what they could be?
Old Oct 26, 2010 | 09:50 AM
  #1414
OKStateG35's Avatar
Originally Posted by NFSP G35
Do 350z front camber arms fit the Sedan???
I've wondered the same thing except with the Coupe arms. I haven't found an answer though.
Anyway, I know everybody was wondering how my non-functioning sidemarkers turned out. Apparently both bulbs were burned out even though one looked completely fine. I have no idea how long they've been out.
I was also able to get the blinker mod working and it actually looks pretty cool.
Old Oct 26, 2010 | 09:55 AM
  #1415
wow good thing it was just the bulbs .weird they were both out at the same time ..
post a vid of your blinker mod . for those who might be interested ..
Old Oct 26, 2010 | 10:17 AM
  #1416
Swivel's Avatar
Moderator
Originally Posted by Hammerhead i-Eagle Thrust
amusing winter wheel color?
Do ett for safety!
Old Oct 26, 2010 | 12:04 PM
  #1417
The Stimulation's Avatar
Yep
Old Oct 26, 2010 | 12:09 PM
  #1418
NFSP G35's Avatar
? = 2B || !2B
^Ok, further on that question (guess I should have asked at first)
Are the stock ones the same? Or will they add neg-camber?
Old Oct 26, 2010 | 12:49 PM
  #1419
That I don't know. Good question actually. If they do add neg camber, I don't think it would be all that much. No more than a degree is what I'm guessing...that's IF it does.
Old Oct 26, 2010 | 12:55 PM
  #1420
Tollboothwilley's Avatar
Stock camber arms should be the same part number so shouldn't add negative camber. This is why people get AFTERMARKET ones and not 350Z arms (or at least part of it)
we are working with the same basic sub framing
suspension parts are all interchangeable - except the X which has some "special" stuff
  #1421
Hammerhead i-Eagle Thrust's Avatar
Originally Posted by SwivelHips
Do ett for safety!
LOL never thought of that, they would stick out in a snow storm...lol and i would be safer from hunters
Old Oct 26, 2010 | 01:18 PM
  #1422
That's what I was thinking. Thought I thought it may be different because the Z is lower since it has shorter springs. Just wasn't quite too sure.
Old Oct 26, 2010 | 02:02 PM
  #1423
OKStateG35's Avatar
This is what I'm thinking. The X, RWD Sedan, Coupe, and Z all have similar suspension setups, but they all sit at different heights. Since there is very little adjustment with the OEM arms, it makes me think they might be different lengths. I have no idea though.
Old Oct 26, 2010 | 02:32 PM
  #1424
I'm guessing that maybe the toe is different? I mean the rears can be adjust only so much, but the front camber can't be adjusted at all.
Old Oct 26, 2010 | 04:00 PM
  #1425
G35Papa's Avatar
The Z probably has more natural camber because of it's ride height/shorter springs. The arms are the same though
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
