Oil Filter Hassle
Old Aug 12, 2010 | 02:18 AM
2slickg35's Avatar
Originally Posted by SwivelHips
Not sure I'd trust the guys who effed it up in the first place, but I'd never go back (and that's why I always do my own!)
Man, that's bad news. Were you able to tell if the filter was cross-threaded, i.e. did the new filter screw on easily? Must have or you'd have said something, I'm sure. Sounds to me like the old one was seized on...wonder how long it was on there? You might also look into whether the 'thread' should have some threadlock on it when reinstalled to prevent this from happening again.
From what I saw, it wasn't cross-threaded. Yes, the new oil filter I put on screwed in easily. By the way, tell me more about the threadlock since I never heard of it.
Old Aug 12, 2010 | 09:08 AM
OKStateG35's Avatar
You can buy it at any autoparts store. It's just a liquid that you put on the threads before screwing it in. It hardens and 'locks' the threads in place. I believe blue is medium hold and red gives a bit stronger hold.
Old Aug 12, 2010 | 09:40 AM
Swivel's Avatar
Moderator
And you can still get it off when you need to; it's not meant to be permanent. What you really need to find out is whether or not that part should be threadlocked when reinstalled. I can't tell from the service manual if it's recommended or not, only to tighten to 36 ft-lbs
Old Aug 13, 2010 | 02:24 AM
thescreensavers's Avatar
Mr.202?
^ Oil gets quite hot, I dont think any thread locker would last long unless there is some pro threadlocker which can easily do the task which I dont know about :P
Old Aug 14, 2010 | 05:35 AM
Blue Dream's Avatar
I drove ttrank's car solo
I don't know about that. If Loctite can lock down a plenum bolt it should be able to hold up on the the oil filter stem.
Old Aug 14, 2010 | 10:40 AM
geew1z's Avatar
^ good point - loctite came with the md plenum spacer. but really you should turn the filter 3/4 turn past the point at which the rubber seal just touches the block.. i've never had one come back out accidentally. i think putting loctite on it is overkill
Old Aug 14, 2010 | 11:28 AM
herrschaft's Avatar
^I agree. I just hand tighten mine all the time (no threadlock) and I have never had a problem.
KruZZe
Feb 27, 2023 05:04 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
mbe32
Nov 13, 2015 11:09 PM
vamarris
Sep 26, 2015 12:56 PM
