DIY beginning of wire tuck
Old Nov 13, 2010 | 12:43 PM
  #106
gmotion04's Avatar
Ok so i also found out that my battery tray is forever staying in the car. Acid from the battery ate off the top of the bolt holding it down haha but i also found out that if your having issues with clearance of the loom over the camber arm bc of the loom running to the horn. Run the loom on top of the black plastic piece that it ran under before. I will get a pic up later once i run by and get the electrical tape 12g and some beeeer.
Old Nov 13, 2010 | 12:51 PM
  #107
NFSP G35's Avatar
? = 2B || !2B
^It ate off one of mine too. I just wedged a claw hammer under there and popped it through. It halfway broke part of the bolthead, and halfway pulled the hole in the plastic tray bigger. Either way, I got it off.
Old Nov 22, 2010 | 03:17 PM
  #108
JBF's Avatar
JBF
welp...since I'm not getting rid of the car anymore, I'll be making an attempt at this...again :/
Old Nov 22, 2010 | 03:28 PM
  #109
CandlestickPark's Avatar
ill Sedan
^Very nice, take a bunch of pics John.
Old Nov 22, 2010 | 04:01 PM
  #110
JBF's Avatar
JBF
I will as soon as I get my P&S camera back from my friend. Sold the D60
Old Jan 5, 2011 | 10:46 PM
  #111
NFSP G35's Avatar
? = 2B || !2B
I think this thread may have already been linked over, but adding another link won't hurt
-----> https://g35driver.com/forums/engine-...wire-tuck.html
Old Jan 5, 2011 | 10:52 PM
  #112
G35Papa's Avatar
Come on Kenny....let's do your main harness....then after we learn, we can do mine
Old Jan 6, 2011 | 02:10 AM
  #113
kennymo's Avatar
chris if you want to help me do it im am totally down for it. only problem is we HAVE to get it done in a day because its my only car. i am taking 2 months off of work starting on the 20th of this month so anytime during that i should be free
Old Jan 6, 2011 | 03:09 AM
  #114
JBF's Avatar
JBF
^ two months?! lucky!
Old Jan 6, 2011 | 11:47 AM
  #115
G35Papa's Avatar
I'll hit you up after next week (waiting to find out some info that will effect my schedule) and we can talk over the details.
Old Jan 7, 2011 | 06:59 PM
  #116
b-dRizZy's Avatar
cant wait to start mine
hating this busy schedule i got..
Old Jan 17, 2011 | 11:07 PM
  #117
JBF's Avatar
JBF
soooo....I have a block on the driverside for the brakes. It obstructs the hole to run the harness through...
any ideas?
Old Jan 17, 2011 | 11:08 PM
  #118
NFSP G35's Avatar
? = 2B || !2B
^Not sure what you're talking about.
Pic?
Old Jan 17, 2011 | 11:17 PM
  #119
Frankieg35's Avatar
any ideas?
What we did was took a hole saw and drilled a hole in front of that box and put in a grommet..
Old Jan 17, 2011 | 11:18 PM
  #120
Frankieg35's Avatar
U see those white clips?? We went to autozone and got clips that go in those holes and hold the harness.. They are called harness clips..
