DIY beginning of wire tuck
Old Oct 6, 2011 | 04:45 PM
  #166
X-FactorWR87's Avatar
CLUB MODERATOR
Originally Posted by NFSP G35
your engine bay looks nasty!!!!!
Old Oct 6, 2011 | 05:46 PM
  #167
NFSP G35's Avatar
? = 2B || !2B
It needs to be cleaned so badly
Old Oct 7, 2011 | 03:32 PM
  #168
jimmyboi860's Avatar
sweeet
Old Nov 16, 2011 | 07:45 AM
  #169
TurboDreamzG's Avatar
When doing the headlight harness I saw where you ran the wires through the inside of the fender. What kind of brackets did you use to secure the wires to the roof of the fender? Also did you drill a hole in the fender and use nuts and bolts to hold it in place or what?
Old Nov 17, 2011 | 05:06 PM
  #170
Brew_haha's Avatar
When i did my swap i did a wire tuck as well. From my experience this is what i found. The factory chassis harness ( the harness that goes to the headlights and non motor controls) can be run down through the bottom holes on either side of the battery and master cylinder compartments, this requires no drilling. The only wires that need extending are the headlight wires. When running i used some adel clamps to hold them to the fender wells and installed the fender well liners. For the engine harness im using a tucked harness from Chase bays, but they do offer tucked VQ harnesses but only for the AEM EMS ECU.
Old Nov 26, 2011 | 09:44 PM
  #171
funnyscreenname's Avatar
polish or at least clean that damn throttle body. sticks out so badly.
Old Nov 26, 2011 | 10:22 PM
  #172
NFSP G35's Avatar
? = 2B || !2B
I know, right! I really want to paint it but I work all the freaking time
Old Nov 26, 2011 | 11:22 PM
  #173
oh, well i know how that is. great job on what you've done so far then. alotta great work you've done.
Old Jan 30, 2012 | 06:05 PM
  #174
seihackguei's Avatar
hm might start this soon! great write up!! =D
Old Jan 30, 2012 | 06:06 PM
  #175
do you think that hood dampeners will work with fiberglass hood? =\
Old Jan 30, 2012 | 06:37 PM
  #176
broke_as_ajoke's Avatar
Nasty as in Good/sweet/sick/cool/on point hehehe
not nasty as in dirty
Old Jan 31, 2012 | 05:16 AM
  #177
Blue Dream's Avatar
I drove ttrank's car solo
You can buy low pressure dampeners designed for lightweight hoods.
Old Jan 31, 2012 | 08:15 AM
  #178
SkylinesTheLimit's Avatar
Once I can find some free time I might try this. Great write-up!
Old Feb 22, 2012 | 07:21 PM
  #179
YOUNG1TRAN's Avatar
i started this today. i was able to hook everything up without cutting. but, for some reason y r the wires running to the headlight so straight/pressured?im worry that the pins might even come out from its plug. is it normal? is everyone having same problem? n i did pull the plug away from the head light to give me that extra 2-3 inch. thanks
Old Mar 12, 2012 | 12:48 AM
  #180
TORETTO's Avatar
bump. bam
Anyone around Norcal (SF peninsula) wanna help me do this. I'll pay you in gum. TRIDENT LAYERS!
