DIY beginning of wire tuck
Old Jan 17, 2011 | 11:19 PM
  #121
CandlestickPark's Avatar
ill Sedan
Yeah we drilled a hole on my driver's side as well IIRC.
Old Jan 17, 2011 | 11:26 PM
  #122
JBF's Avatar
JBF
This is taken facing the rear of the car. The hole utilized for the wire tuck is directly to the right and below the "MC" in the block. There isn't any room for me to maneuver the wires in there....
Old Jan 17, 2011 | 11:28 PM
  #123
NFSP G35's Avatar
? = 2B || !2B
^Ah. The ABS pump assembly.
Old Jan 17, 2011 | 11:31 PM
  #124
Frankieg35's Avatar
That's why u have to drill a hole!! Haha Did u see the pic I posted a page back??
  #125
JBF's Avatar
JBF
damn so I have to pull the fender off? wow!
Old Jan 17, 2011 | 11:40 PM
  #126
JBF's Avatar
JBF
I have a 3/4" step bit. Would that be big enough? Or should I allocate a bigger one?
Old Jan 17, 2011 | 11:43 PM
  #127
SxExCx's Avatar
^Go to Harbor Freight and buy a full hole saw kit for under $10
Old Jan 17, 2011 | 11:51 PM
  #128
JBF's Avatar
JBF
all the available hole saw kits wont cut metal. How big of a hole does it need to be?
Old Jan 18, 2011 | 12:03 AM
  #129
G35Papa's Avatar
I was able to get the harness passed the block and into the drain whole already there...no drilling needed. You just have to smash/push it all passed the block
Old Jan 18, 2011 | 12:04 AM
  #130
SxExCx's Avatar
It might not saw that is meant for metal but they WILL cut metal...trust me.
I would say to get like 1.5" so you have room for a good grommet.
Old Jan 18, 2011 | 12:06 AM
  #131
JBF's Avatar
JBF
That sounds like WAY too much work for me. lol. But then again, so is removing the fender lmfao
Old Jan 18, 2011 | 12:11 AM
  #132
Frankieg35's Avatar
U might be able to drill from inside out and keep the fender on.. but u would have to be careful.. dunno we did it without the fenders on..
Old Jan 18, 2011 | 12:17 AM
  #133
G35Papa's Avatar
Originally Posted by Johnnys_Beast_Foo
soooo....I have a block on the driverside for the brakes. It obstructs the hole to run the harness through...
any ideas?
No I remember what I did, it's been a while...when I did my friends coupe, his fender was off and I was able to get everything behind THE BOX and through the OEM whole. For mine, there was a whole on the lower floor of the firewall...
Box is to the right in this pic.
Old Jan 18, 2011 | 12:18 AM
  #134
ill Sedan
We didn't take the fenders off when we did mine, so its possible to do with the fenders still on, but like frankieg35 said you gotta be really careful. Since your car is parked its just safer to remove the fender John.
Old Jan 18, 2011 | 12:21 AM
  #135
Frankieg35's Avatar
Or u could be the first to run the wires on the outside of the fenders.. Start a new trend!!
