Intake Modification
Old Oct 8, 2010 | 01:26 PM
darddoo's Avatar
Intake Modification
I installed an AEM cold air intake into my 03 G35 sedan, I have a jim wolf pop charger on the way, but i was wondering if the pop charger is going to fit with the cold air intake since its all the way on the floor of the engine bay. Or is it not going to be able to fit at all ? any input on this. does anybody have an intake and a pop charger ? thanks.
Old Oct 8, 2010 | 01:40 PM
Jeff92se's Avatar
Red Card Crew
How are going to attach the JWT velocity stack onto the AEM pipe?
Or if you are just using the filter, then how are you going to attach a filter with a 6" opening to a pipe that's 2.75" or 3"?
Old Oct 8, 2010 | 01:49 PM
3truman's Avatar
Wow, good luck with that!
Old Oct 8, 2010 | 01:51 PM
darddoo's Avatar
make pipe opening that fits both the pop charger and the intake ? or just remove the intake and go z-tube and pop charger ?
Old Oct 8, 2010 | 02:28 PM
3truman's Avatar
You could run both, but it seems a bit much. I have just the pop charger and it gets heat soak in the summer but fall spring and winter its great!
Old Oct 8, 2010 | 02:29 PM
Jeff92se's Avatar
Red Card Crew
Um how are you going to run both?
Old Oct 8, 2010 | 03:25 PM
drkay's Avatar
doesn't the AEM cold air intake already have a cone air filter (aka pop charger) at the end of the tube?
Old Oct 8, 2010 | 04:36 PM
SN00P's Avatar
CLUB MODERATOR
why don't you just use the AEM intake or the pop charger and z tube ?? why mix and match things ??
Old Oct 8, 2010 | 04:39 PM
Jeff92se's Avatar
Red Card Crew
Because he only has the filter from the pop charger. (I guess)
Old Oct 8, 2010 | 04:43 PM
SN00P's Avatar
CLUB MODERATOR
well IMO i would get the z tube with the pop charger .. i had that set up on my car and it was great ....
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
vamarris
Sep 26, 2015 12:56 PM
