Bose radio
Old Oct 25, 2010 | 01:15 PM
MAR777INE's Avatar
Bose radio
I HAVE A 2006 G35 SEDAN. I AM ON MY 3 HU IN ONE MOUNTH. IS THERE A BUILT IN AMP ON THAT RADIO? 0 TO 15 NO VOL 15 TO 31 NOT VERY LOUD? i WAS TOLD i DON'T NOT HAVE A EXTERNAL AMP. SO IS THERE ONE BUILT INTO THE RADIO. IF SO CAN IT BE CHANGED AND WHERE WOULD YOU GET ONE. THANKS FOR THE HELP.
Old Oct 25, 2010 | 01:19 PM
thescreensavers's Avatar
Mr.202?
Old Oct 25, 2010 | 02:22 PM
geew1z's Avatar
If its actually a Bose radio, there is an amp upside down on the rear deck, accessible from the trunk.. yth you would want to buy another blose amp is beyond me. I have one for 150 bux though
Old Oct 25, 2010 | 02:23 PM
Junkyardspecial's Avatar
There is an amp in the car that the Headunit is wired to. Your best bet is not buying the OEM bose head unit and getting a Double DIN kit. Much better sound quality and you won't have a crap Unit.
Also,
Old Oct 25, 2010 | 03:08 PM
MAR777INE's Avatar
I do have a Bose HU. I replaced it because of error codes. When I replaced it the volume on the HU was bad. 0 to 15 no sound 15 to 31 not much. Put old HU back witch had a GREAT kick and volume. When I put it back it did the samething as the new used one. Poor volume. I was told 2006 did not have externail amp in trunk. I took everything out to check. NO AMP.
Old Oct 25, 2010 | 03:10 PM
G35SedanGrn's Avatar
Then you sir, must not have Bose...
Old Oct 25, 2010 | 03:12 PM
geew1z's Avatar
you took down the felt on the underside of the rear deck?
Old Oct 25, 2010 | 03:46 PM
blazeplacid's Avatar
no amp on rear deck = no bose
easy way to check. look at the rear deck. Does the middle speaker cover say bose?
Old Oct 25, 2010 | 04:14 PM
MAR777INE's Avatar
Wow do i feel stupid. Your right. So i put my face on the bose hu. I will make the change tonight. Thank you.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
Learned Hand
Oct 1, 2015 09:02 AM
mattdg35
Sep 14, 2015 11:28 AM
