Car makes Grinding Noise.
Hello all, today i was driving home till an idiot in a mercedes slid nearly hitting me . so i slammed my brakes and turned away from him and while the wheels were turned to the right so i slid into a curb , denting my front left driver rim. It was a pretty hard hit luckily he didn't hit my car but now when im reaching speeds over 25 a hard grinding/rubbing noise . Did i damage either bearings or the wholel axle please help . I have been having the worse luck this week thanks everybody..
:bang head:
:bang head:
u shoulda prob let him hit your car
i mean he would have had to fix it for you.
edit: why do you not check under the wheel.. take it off and inspect the area.
i mean he would have had to fix it for you.edit: why do you not check under the wheel.. take it off and inspect the area.
did u inspect all the metal stuff around? made sure nothing was dented or cracked or broken? hopefully someone can verify if its the bearing.
rezendvous420
May 31, 2020 01:26 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
