idle issue...Possibly related to TB cleaning?
Old Jan 11, 2011 | 02:33 PM
alexh521's Avatar
A couple weeks ago i was having idle problems; took it in to my mechanic and said that it could just be a dirty Throttle body. I had him clean it and put a new transmission pan gasket in as well since my other guy forgot too . the next day when i get it back i get a CEL and it comes back with an idle issue... I just did some reading anout how prissy our TBs can be and im wondering that if my mechanic just took it out and cleaned it with soap, water, and a toothbrush if he could have really screwed up my throttle body.
Any input?
Old Jan 11, 2011 | 02:55 PM
G'ed's Avatar
is your idle too high or too low?? I'm currently experiencing some issues with my idling as well. my SES light came on and i went to pull the code. It tells me that my idle RPM is higher than expected.
Old Jan 11, 2011 | 03:13 PM
AARONHL's Avatar
Idle re-learn procedure??
Old Jan 11, 2011 | 03:16 PM
socialconflicts's Avatar
^i have heard that is a pain... but goodluck
Old Jan 12, 2011 | 01:59 AM
G'ed's Avatar
^how do you do ldle re-learn??
Old Jan 12, 2011 | 11:41 AM
AARONHL's Avatar
Very easy if you have a stop watch!!!
Old Jan 12, 2011 | 11:42 AM
AARONHL's Avatar
Use the search menu...
Old Jan 12, 2011 | 07:41 PM
alexh521's Avatar
mines too high... and you have to do every other procedure before you get to the idle re-learn lol
Old Jan 12, 2011 | 07:45 PM
i think the idle relearn is done by unplugging the negative. but i also read somewhere else that the computer is always adjusting to a cars changes so it isnt needed.. but thats obviously not the case.
Old Jan 12, 2011 | 08:51 PM
CG4DR's Avatar
ask him if he moved the throttle plate itself, if so you need a new TB because he messed up the little gears inside. I had the same thing happen to me.
and as far as the idle relearn its really simple
http://www.line-it-up.org/threads/22...earn-procedure
Freeman186
Sep 6, 2023 10:07 AM
Thebaws11
Jul 2, 2021 11:36 AM
NJ6MT
Sep 10, 2015 08:40 AM
esotericrider
Northern California
Sep 10, 2015 02:28 AM
Jnm07
Sep 5, 2015 01:16 AM
