odd front strut noise
Old Mar 14, 2011 | 03:11 AM
  #76
socialconflicts's Avatar
Originally Posted by kennymo
they wont notice. the dealer actually didnt even trip that i was on coils when i went in and they told me i needed my comp rods replaced so they did it under warranty.
but i think i may know what my clunk noise is now. still need to check out. i think the preload settings on my coils might be off which is allowing my spring to move up and down when there is no load on them.
well when i took my car in for work to the dealer in my area they actually didnt wanna work on it cuz i had rear coils on... lol
Old Mar 14, 2011 | 10:37 PM
  #77
RADIOGUY21's Avatar
Originally Posted by TOYSTA
Did you attempt??
I don't know what I should try to replace first. I don't have the cash to go replacing diff parts lol.
not yet. Its just finally starting to warm up here so if weather allows, this weekend I'll work on it. I'm too lazy to work in the cold
Old Mar 15, 2011 | 08:02 AM
  #78
theophilus's Avatar
i'm going in for an oil change and the steering wheel/door insert check from wear. I'm going to have to ask them about this clunking...except mine isn't as pronounced. The car drives fine, but when going over bumps I hear padded thuds...I'm not sure if it's normal or not but it happens all the time and it sounds like something might be loose.
Old Mar 16, 2011 | 01:15 AM
  #79
akoustic's Avatar
I'm still experiencing this. Going to my mechanic this Saturday if I'm not forced to work....
I will update once I get back. Meanwhile.... keep'em coming!!
Old Mar 20, 2011 | 09:12 PM
  #80
GNY's Avatar
GNY
I had the same noise and spent 1850 to fix it as follows:
New struts/strut mount/spring seats - this cures the clunking>
New swaybar endlinks - if your struts are old, your endlinks will be worn also.
compression rods - not sure if they make noise when bad but i could feel the unibody flex by my foot when hitting bumps.
after changing all this car handled like new...no more clunking, creaking, or chasis flex.
Old Mar 20, 2011 | 10:27 PM
  #81
akoustic's Avatar
update on the noise.
The bushings on my compressions rods are going.
Check you compression rods folks!
Old Mar 21, 2011 | 04:28 AM
  #82
seems like you overpaid.... :\
Old Mar 21, 2011 | 04:29 AM
  #83
the control arm bushing?
Old Mar 21, 2011 | 10:57 AM
  #84
DaveB's Avatar
Guys with lowering springs, have you made sure that the spring rubber isolaters are in place and in good condition? If the isolater isn't there or is worn, the springs can make clunks and thuds, especially over rutted or slightly bumpy surfaces. What can happen is the springs can tap on each other and without the isolaters or split ones, it can make some annoying sounds.
Old Mar 22, 2011 | 03:44 PM
  #85
UPDATE
so got back from the dealer, and well i couldnt be any happier leaving! amazed huh? :P
anyhow.. i went in there lowered... i was certain i was going to get told the noise is due to your struts or something having to do with me being lowered (since i got told this before) but this time was different. they actually checked the problem and you bet they found it! and i was covered under my extended warranty !!!!
the problem for me was the endlinks. so they were replaced and damn, my car seems very firm now.. bumps or little cracks on the roads seem to handle better, the swaybar seems more stiff and on point than before. im very happy with the outcome
hope everyone else figures out their problem. and if anyone is interested i got a front strut end mount for sale.
Old Mar 23, 2011 | 05:58 PM
  #86
RADIOGUY21's Avatar
nice dude. I would love a quiet non-clunking front end right now. Got an appointment Saturday to have my sway bushings swapped and hope to report good news.
Old Mar 23, 2011 | 09:16 PM
  #87
stinkytofu89's Avatar
Wow awesome! I hope to replace mine soon as well
Old Mar 24, 2011 | 09:35 AM
  #88
equilibrium's Avatar
Are end links expensive? I am bone stock and I hear clunking from the passenger side, it's only on small bumps though, and it feels like it's continuous. It almost feels like something is loose but it's not so important, lol like some piece of plastic hitting something.....neway it's a guessing game but I was just wondering if the end links where hard to replace!
Also, the bushings for the LCA, is there a way to fill this with urethane same as some guys do for their motormounts?
Good luck to everyone with the clunking issue, and it looks like it's a G clunking month!
Old Mar 24, 2011 | 11:32 AM
  #89
Endlinks are actually very easy to replace and if it's not the endlinks seems like your control arm bushings are going bad. For those u would need to buy the bushings and have a shop press them in.
And they are not expensive. Maybe like 50-60 bucks for the endlink pair
Old Mar 24, 2011 | 01:35 PM
  #90
thanks, I will def. check into that, however I don't think it's the control arm bushing....I replaced the driver side when it was clunking, and it was a different clunk, i could be wrong tho!
