odd front strut noise
Old Feb 14, 2011 | 03:43 PM
socialconflicts's Avatar
so im getting some clunky noise coming from my front driver side strut when going over slight bumps, almost feels as if its loose, i have checked everything and under the rubber to see if any leaks from the strut, but all is clean.. any ideas what else it can be?
oh, i also checked the sway and bolts all around the strut area and nothing is loose or missing.
Old Feb 14, 2011 | 04:08 PM
gtivr698's Avatar
check your control arm bushing see if tore
Old Feb 14, 2011 | 04:11 PM
Blue Dream's Avatar
I drove ttrank's car solo
Or same problem on the compression rod. How low are you dropped and how many miles on your car?
Old Feb 14, 2011 | 04:45 PM
I'm dropped on sportlines so I think it's like 2.5 inch drop, car is about to hit 60k it started to happen after I took it on the palomar run we had here in San Diego. Struts have about 17k on them. I don't think it's the bushing because I had those replaced before and the noise of bad bushings is a squeak and not a clunky noise as I'm experiencing.. Unless I'm wrong
Old Feb 14, 2011 | 05:09 PM
kennymo's Avatar
im having the same problem on the same side. mine started when i put my coilovers on though. i dont think its the compression rods because those were brand new about 1k miles ago.
Old Feb 14, 2011 | 05:11 PM
Blue Dream's Avatar
If your compression rod or LCA bushings wear out they can clunk when the head of the arm bangs against the mounting brace. Here are a couple of pics to illustrate. The poster of the pictures hit a pothole at 60K miles and broke the bushings.
Old Feb 14, 2011 | 05:13 PM
kennymo's Avatar
is that a picture of the lower control arm bushing?
Old Feb 14, 2011 | 05:18 PM
Ima have to look again more carefully but I think if I saw that I would have noticed. And also what Kenny asked
Old Feb 14, 2011 | 05:39 PM
kennymo's Avatar
i just looked at my control arm bushings with the car still on the ground, i just turned the wheels to the side. the control looks fine and from what i can tell the bushing looks fine. the control arm is sitting in the middle of the bracket centered like its supposed to. now im getting kinda scared because i have no idea what it is. i was kinda hoping thats what it was
Old Feb 14, 2011 | 05:49 PM
Blue Dream's Avatar
Yep those are pics of the LCA. If either of you are running SPC front camber arms they've been known to clunk on low cars.
Old Feb 14, 2011 | 05:52 PM
kennymo's Avatar
i have all stock arms. if it is the lca bushing or the comp rod bushing. would i be able to jack the car up and take the wheel off so there is no load on them and shake them side to side? or would it only move if the car is on the ground?
Old Feb 14, 2011 | 06:04 PM
So the pic posted is of re upper arm? Or lower? From what I can see it's the lower control arm
kennymo's Avatar
yea its the lower.
Old Feb 14, 2011 | 07:25 PM
Blue Dream's Avatar
That's right^^ They are from under the car looking up.
I don't think you could move the rods back and forth, but it's super obvious just looking at them if they're OK. When they fail that will also affect your alignment. The SPL bushings are a really good replacement if you're willing to spend the money.
Old Feb 14, 2011 | 07:32 PM
kennymo's Avatar
so if i looked at them and it looks like they are centered then they are probably good?
