Transmission grounding wire for AWD
Old Feb 20, 2011 | 11:59 PM
ccc123pm's Avatar
X
So my transmission grounding wire has been sitting around for a while waiting to be put to use. In Sean's instructions it says to attach the grounding wire to ID tag on the trans. The only problem is that the front driveshaft is in the way and it is nearly impossible to get a ratchet or a wrench to that location. Any ideas or pics of where other members have attached this wire?
note: mods please do not move as this is relevant to first gen sedans
Old Feb 21, 2011 | 10:35 AM
Mustang5L5's Avatar
I know many won't agree, but....
Doesn't matter. Transmission is bolted to engine so if you put any ground wires on the engine already, then you've grounded the trans too. Another wire on the trans won't make a difference.
Old Feb 23, 2011 | 09:58 PM
semicycler's Avatar
I installed the stealth version of Sean's kit on my 2004 G35X. The transmission wire was a complete PAIN IN THE A$$!!!
You have three options:
1. Don't install it. If your shifts in manual mode are quicker than before installing the rest of the kit, be happy. If you don't notice any change without the transmisison wire or you are OCD like me and must install the complete kit, go to step 2
2. Attempt to connect the wire without removing the drive shaft. I did manage to make it work but it took two sets of universal swivel socket adapters, multiple sizes of socket extension bars with the socket locking features, and a mirror and flashlight to see around corners. Patience, beer, patience and more patience.
3. Or just bite the bullet and drop the drive shaft. Honestly without a lift this looked more difficult to me than step 2.
I don't regret installing the transmission ground wire on the X even with it being such a pain. I definitely notice a HUGE difference in snappier/quicker shifts in manual mode with the full kit. Before installing the full kit, manual mode was on occaision for me, mostly for downshifts. Now with the kit I'm always in manual mode except when I need my second hand to fiddle with the GPS, phone, etc. No regrets! But what a pain!
Good luck!
Old Feb 24, 2011 | 10:21 AM
ccc123pm's Avatar
X
hmm, I definitely have the tools, and im unemployed right now so I definitely have the time. I guess I was just wondering if there was an easier way. Thanks for the encouragement.
Old Feb 24, 2011 | 02:12 PM
Kuneff's Avatar
I don't see any way possible it would matter... If your worried about it find a bolt somewhere easier to get to and bolt it to that... Its all connected so it would not matter.
Thats just my .02
Old Feb 24, 2011 | 07:22 PM
ccc123pm's Avatar
X
I agree, that's why I was asking if anybody had any alternatives.
Old Feb 25, 2011 | 10:32 PM
davidxu's Avatar
i just bolted mine on a random bolt on the transmission case..
Old Jun 23, 2011 | 10:40 PM
BuckeyeInMI's Avatar
A little late coming to this party, but here's where I bolted mine. This is on the driver's side.
Attached Thumbnails Transmission grounding wire for AWD-transmission_lower.jpg
Old Jun 24, 2011 | 01:22 AM
ccc123pm's Avatar
X
thats where I ended up attaching mine. I took off that whole bracket, cleaned the metal on the trans with a dremel and sandwiched the bracket over the wire.
Old Jun 24, 2011 | 07:44 AM
GXXXV X's Avatar
can someone please contribute some pictures showing me where on the car is this thing and which bolt to use and how to get the wire down there please, i dont want to have the wire wrapped around the front bumper i want it to be hidden
Old Jun 28, 2011 | 01:00 AM
Mine goes from the top back left of the engine down along the firewall diagonally to the driver's side of the transmission. It's not easy to put it on the transmission (see my pic), but it's the best place I could find. Like cc123pm, I had to remove the bracket, including snipping the zip-tie holding the black cable on. I used a short bolt and nut to connect the grounding cable to a hole in the bracket, then re-attached the bracket to the transmission.
It's a pain to attach it to the AWD tranny, but it's definitely worth it. Crisper shifts for sure.
Old Sep 5, 2011 | 06:05 PM
novarider79's Avatar
Removed.
Last edited by novarider79; Sep 6, 2011 at 05:06 AM. Reason: Removed - Wrong Forum
Old Sep 5, 2011 | 11:05 PM
ccc123pm's Avatar
X
^ looks like a second generation sedan... the issue was with the first gen because there is nowhere near as much room.
Old Sep 16, 2011 | 12:19 AM
t3_123's Avatar
I no this is old but i have an g35x 05 an it was hard but take a deep breath an take the scratches. I got mine on the way sean said to run it but took about an hour just for that an the tag that was on it i cant put back on. But the shifts are great.
Old Sep 16, 2011 | 01:02 AM
Trickstyle's Avatar
can someone plz link "seans instructions"? I have an 03 coupe but i cant see it being that different...
