DIY: halogen to HID conversion (ebay lights)
Old Jan 11, 2013 | 11:20 AM
  #61
Mustang5L5's Avatar
Originally Posted by Peoria35sedan
Your lights have no cut off at all, how can you claim there is no glare? A new camera is not going to add a cut off line.
You are correct. That's as good of an example as glare as you can get.
I've actually seen quite a few G35's with halogen headlights and retrofit kits installed and think they are one of the worse glaring headlight designs out there. The difference between OEM HID's and halogens with HID's is huge.
I know that some vehicles, with certain headlight designs are tolerable, but my opinion is the G35 is not one of these.
(referring to 03/04 halogen low beams...not fog lights)
Old Jan 11, 2013 | 12:12 PM
  #62
gdriver2010's Avatar
this is what i consider glare, light reflections everywhere. I do not have that issue, and i do not have projectors and therefore will not have a super clean cutoff, look at factory 02-03 maximas for example, the have factory non projector HID headlights and have the same light dispersement as i do
Attached Thumbnails DIY: halogen to HID conversion (ebay lights)-57760d1181626841-hid-glare-removal-mod-will-affect-lighting-mad_glare_disaster_hid_kit_in_haloge.jpg   DIY: halogen to HID conversion (ebay lights)-images.jpg
Old Jan 11, 2013 | 12:24 PM
  #63
NFSP G35's Avatar
? = 2B || !2B
It must depend on the bulb, because I compared the HID and halogen bulbs side by side before installing, and the chamber in the HID is in exactly the same spot as the filament on the halogen.
Old Jan 11, 2013 | 12:50 PM
  #64
Peoria35sedan's Avatar
We all have reflectors, and my car has a pretty clean cut off, I beliveve this picture is of the factory cut off, mine looks almost exactly the same.
CutofOEM.jpg?t=1269654080
Old Jan 11, 2013 | 02:21 PM
  #65
Mustang5L5's Avatar
That's exactly my point. There isn't a standard for the H1-based HID. It's an aftermarket hybridization of two different bulbs. There is no conformity standard of these hybrid bulbs that garantees the product produced by one company is the same as one produced at another.
If you really think about it, why wouldn't the manufacturer (nissan, toyota, Honda, Ford, etc) simply use halogen replacement bulbs and stick to one headlight housing design? Simply remove the halogen bulb and replace it with a corresponding HID-replacement bulb? I have my theories, but that's a whole different topic of conversation here
Old Sep 12, 2022 | 09:31 PM
  #66
G35CO's Avatar
Do I need to buy an adapter if I don't plan to use the HID bulb? I'm okay downgrading to halogen.
Just looking for a cheap fix to my broken headlight and don't want to spend $500 for HID headlight housing.
Old Sep 13, 2022 | 07:11 PM
  #67
Scubasteve93's Avatar
Working progress
Led fog lights
H4 fog light hi beam led
Amazon $20
New one on left
Old Sep 13, 2022 | 07:29 PM
  #68
G35CO's Avatar
I currently have HID housing and I'm thinking to buy the cheaper halogen housing. Do I need to by adapter if I change from HID housing to halogen housing?
Jusseth
Sep 13, 2020 12:25 PM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
julian.dion
Lighting
Jul 29, 2015 12:47 AM
attarday
Jul 15, 2015 04:03 PM
