tien s tech with 19s
Old Apr 1, 2011 | 12:13 AM
tommyb985's Avatar
have a 04 black on black 6sp manual,i recently ordered the tien s tech springs,lowers the front 2in and the rear 1.3in,i have 19 inch tenzo type r with 245/45,am i going to rub at all?any tips would be appreciated,new to the car game.always owned trucks,thanks guys.
tom
Old Apr 1, 2011 | 12:24 AM
kennymo's Avatar
depends on what you offsets are
Old Apr 1, 2011 | 05:59 AM
Blue Dream's Avatar
I drove ttrank's car solo
You will need to roll your fenders in the rear or you will rub. Are you sure your tires aren't 245/40? If they are 45s you might need to flatten your fenders as well, those are some tall tires.
Old Apr 1, 2011 | 06:39 AM
tommyb985's Avatar
Angry
yea they are deff. bridgestone turanza 245/45/19,how do i figure out my offset?i have another set of tires,245/35/19 but i hit so many potholes it kept bending my wheel with those tires so i got bigger ones,the 245/35 i just need one tire and i cuold put those back on,id rather not because the ride is so nice with the 45s,but if i have too,i dont have a choice yanno
thanks tom
Old Apr 1, 2011 | 11:00 AM
AwdGx's Avatar
Im on the same springs..245/35 tire and no rub without rolling fenders
Old Apr 1, 2011 | 11:33 AM
JaysG35x's Avatar
Yes 245/35 should be fine. 245/45 is a tall tire witch is not so good for lowered cars.
Old Apr 1, 2011 | 01:03 PM
Tollboothwilley's Avatar
i went from 245/35 to 245/40 all around and I rub in the front right during a hard turn every now and again. I'm am on 350Z H-techs which lower about 1.5-2" all around.
Old Apr 6, 2011 | 06:10 PM
tommyb985's Avatar
Thumbs up
the springs will be here tommorrow,i ordered a roller also,i think if i roll the front i should be okay,i dont want to run anything smaller then a 45 tall tire,i crack rims too much in my town,its horrible,ive been through like 3 different sets.i got the best ride with the 45.ill post pics and tel everyone how it comes out,thanks guy i appreciate it.
Old Apr 6, 2011 | 08:22 PM
4D05G35's Avatar
That will determin if you will rub or not.
thanks tom
245/45/19. dang. Thats over an inch larger than stock. If you need some sidewall I would recomend that you go with 18's instead of 19's.
The offset is often on the back side of the wheel, if not you can measure the distance from the center of the wheel (inner lip and outer lip) to the mounting surface of the wheel to get the offset.
KruZZe
Feb 27, 2023 05:04 PM
prinny
Nov 22, 2015 11:07 PM
AJC128
Nov 1, 2015 11:55 AM
bigmike
Sep 17, 2015 01:58 PM
