Black Housing Headlights - ebay
Old May 10, 2011 | 05:48 AM
GeNOS's Avatar
anyone used the headlights for the 35 sedans on ebay that have the black housings??? are they anygood???
anyone recommend any particular ones to buy or avoid?
cheers
Old May 10, 2011 | 07:52 PM
NFSP G35's Avatar
? = 2B || !2B
blksedan4me has them.
Old May 10, 2011 | 08:36 PM
ronniepetras's Avatar
cheers
I wouldn't recommend you buying them I had them I Ended up selling them on craigslist
Old May 10, 2011 | 08:42 PM
GeNOS's Avatar
why reason?? didnt throw enough light?
Old May 10, 2011 | 08:56 PM
You just answered your question
Old May 12, 2011 | 05:14 PM
Midwest-G's Avatar
Old May 12, 2011 | 06:35 PM
GraphiteX's Avatar
if they are anything like the black housing ebay headlights i had on my old civic about 6 years ago, the coating or something on the clear plastic flaked off and the sills didnt last, air and water leaked in
Old May 13, 2011 | 01:20 AM
GOAT35's Avatar
Your going to end up opening them up and doing more work than you wold just painting the oem ones. I would only say go for it if you plan on doing mods to the lights like a retrofit that way you will seal them back nicely and treat that lens because its far shyttier than the already shyty lens that turns **** yellow if not treated once every 3 months. Well maybe that just an issue with me.
Old May 14, 2011 | 11:32 PM
NjMatteSedan's Avatar
they're fine but if you plan on keeping them for a long time i suggest 2 things, 1) black sillicone all around the seals to prevent condensation and 2) a clear vinyl protective film on the lenses as the lenses are more delicate and prone to scratches than oem headlights
Old May 15, 2011 | 11:10 AM
JaE35's Avatar
Moderator
G35 Sedan
I'm considering just spending the 250 on oem replacements just for the outter plastics...mine are done they are far beyond wet sanding
Old May 15, 2011 | 12:02 PM
^ the outer plastics are not a direct fit on the oem headlights
Old May 15, 2011 | 12:42 PM
NFSP G35's Avatar
? = 2B || !2B
I have yet to see G35 headlights that are actually beyond wet-sanding
Old May 15, 2011 | 12:54 PM
JaE35's Avatar
Moderator
G35 Sedan
i wouldn't buy these black ones if that's what your referring to
Old May 15, 2011 | 12:59 PM
JaE35's Avatar
Moderator
G35 Sedan
i had previously smoked my headlights a while ago and to take off the smoke i used goof off and it damaged the plastics on one side pretty bad from sitting too long
Old May 15, 2011 | 08:47 PM
NFSP G35's Avatar
? = 2B || !2B
^have you tried sanding them yet? (I mean REALLY sanding them, starting with like 400 or so on a machine, and then moving up in grit)
