Just to double check...correct, or incorrect part
Old Jun 16, 2011 | 09:18 PM
Mustang5L5's Avatar
I need a new DRIVER's side rear caliper.
THIS, is not a driver's side correct?
The caliper, if looking at the wheel into the car, with the front of the car being on the left, sits at the 9 o'clock position. That would put the bleeder on this caliper on the bottom...which is incorrect.
SO, just so i know i'm right...this is a passenger side caliper right??
This is the SECOND wrong caliper rockauto has sent me. To be fair, the part number does match the number on their site listing a driver's side caliper, but this is the second passenger side caliper they sent.
Guess i need to get a 3rd caliper.
Old Jun 16, 2011 | 10:09 PM
ccc123pm's Avatar
X
looks like passenger side to me.
Right rear caliper is nissan #44001-am800
Left rear caliper is nissan #44011-am800
Old Jun 17, 2011 | 12:28 AM
NFSP G35's Avatar
? = 2B || !2B
Driver's Side:
Old Jun 17, 2011 | 05:16 AM
VincenzG35's Avatar
funny me and ash realized this seems to be a common problem on this specific caliper the pistons seem to freeze and no longer compress i changed mine in march
Old Jun 17, 2011 | 07:00 AM
Mustang5L5's Avatar
Knew I wasn't crazy....back it goes a second tome
Old Jun 17, 2011 | 11:41 AM
blklude98's Avatar
If you can wait, I'm going to be swapping to brembo's. I have an 06 RWD sedan so I have the same brakes as you. I'm going to sell the whole brake setup. HPS pads/centric rotors
Old Jun 18, 2011 | 11:51 AM
Mustang5L5's Avatar
ALready sent it back and have the "correct" caliper on it's way now...but thanks
Old Jun 19, 2011 | 02:09 PM
GreenPenguin's Avatar
+1 Replaced mine around the same time. Wish I had done some type of treatment on the new caliper before install- the new one I put on has rusted. Heads up to the OP
Old Jun 19, 2011 | 03:58 PM
Mustang5L5's Avatar
Yes, already aware of it. Oroginal caliper is rusted to hell. When I pulled the pads out, the piston had tons of rust in it. The reason I am replacing the caliper is that the slide pins had seized so only the inside pad pressed the rotor when I hit the brakes. The outer pad is just along for the ride.
The other caliper wasn't that bad. I cleaned it up with wire brush, primed and then painted the caliper. Then i relubed the slide pins and filled the boots with high temp grease. Should protect it for some time. Will do the same to other new caliper.
Some point down the road, I'll pull both off an inspect. If the other caliper looks worse, I'll just replace it.
Plur
Audio/Video/Electronics
Jun 1, 2020 08:25 AM
RA081024
Aug 18, 2015 07:03 AM
EPG35
Aug 16, 2015 04:52 PM
Frankieg35
Aug 15, 2015 10:49 PM
itztwinki3
Aug 1, 2015 12:58 AM
