Yaw/G sensor malfunction (VDC light on, Slip light on) Error Code C1145: need HELP!
Old Jun 23, 2011 | 04:25 PM
bigjee's Avatar
Hey everyone.
I just got back from the dealership where I was getting an code diagnosis done because my SLIP and VDC OFF lights were on.
Error code is C1145 on the scanner.
The tech tried to reset the codes and the TSB instructs him to replace the sensor if that doesnt clear the lights.
Since the lights didnt trun off it seems I have to replace it.
The cost for this "yaw sensor" is $1357 and with installation it comes to a little over $1500.
So if anyone has a spare yaw sensor lying around for their G (I know that a lot of ppl have disabled the yaw sensor for spirited driving) I was wondering if you could help me out.
I don't want to and I can't spend so much money for this sensor.
As like most of us here I love my car but the high cost of this part really leaves me no choice but to buy a used part.
Please help.
The part number is 47930-AL700
Any input would be appreciated.
Also what kind of manufacturing years carry the same sensor?
Is it the same for an 2003-2006?
Thanks again.
47930-AL700
UPDATE 1:
Found a cheaper one on eBay (listing has expired)
Yaw sensor Bosch on eBay
Looks like this:
Even though the part number says AL 704 instead of AL700 I think it'll fit but since the listing has expired I'll keep looking.
Update 2:
Found another listing but the part number doesn't match up at all:
47931 JK00A
Old Jun 23, 2011 | 04:59 PM
thescreensavers's Avatar
Mr.202?
Dont buy it from the dealer. Its just the Bosch Sensor under the arm rest?
Also people install a switch, they dont remove the yaw sensor, for when they dont want VDC.
Old Jun 23, 2011 | 05:34 PM
bigjee's Avatar
Hi yes its this sensor:
Looks like the same part.
Old Jun 24, 2011 | 02:32 AM
bigjee's Avatar
Found a good thread/post showing this sensor in detail and what it does:
https://g35driver.com/forums/4723889-post85.html
Old Jun 29, 2011 | 02:55 PM
gambit2083's Avatar
here you go...
http://cgi.ebay.com/ebaymotors/2003-...item27ae76b454
enjoy!
Old Jun 29, 2011 | 03:00 PM
bigjee's Avatar
Originally Posted by gambit2083
Thanks for the link, but I got my hands on one which was slightly cheaper (its in the mail as I type).
Only downside is that its untested and used so I don't know whether it'll work properly until I get it installed (which is a $150 charge) so fingers crossed it will work.
Here's the link for the item:
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=280646605358&ssPageName=STRK:MEWAX:IT
Old Jun 29, 2011 | 03:04 PM
Mr.202?
Install it your self, its easy. Its right below the arm rest.
Old Jun 29, 2011 | 03:10 PM
bigjee's Avatar
Will the "VDC OFF" and "slip" light turn off after I install this part.
Dont the codes have to be reset with a scanner?
Plus I don't know how to take apart the arm rest.
If its simple tools like a Philips screw driver I can do it (i've never worked on my car and don't have any special tools)
Old Jul 12, 2011 | 01:06 AM
BH818's Avatar
I have one for sale to
$80 :P
https://g35driver.com/forums/drivetr...ml#post5992241
Old Nov 9, 2012 | 03:50 AM
Ednica87's Avatar
Hey could u give me an update on what u did? Also if it worked or what? Did u replace part or clean it like I've been hearing other people do thanks.
Old Nov 12, 2012 | 05:40 AM
bigjee's Avatar
I had the dealership install it in about an hour.
Total cost was part and 1 hr of labor.
i replaced the old part.
If the part works the vdc and slip light will turn off.
Old Nov 12, 2012 | 07:37 AM
Mustang5L5's Avatar
To reset the code, you can just unplug the battery for half an hour. You'll lose all your presets and such, but it will do the job. Otherwise you can run to autozone, ask them to use their scanner and reset it.
Or, you can search ebay for a cheap OBD-2 scanner and never pay $90 to read a code again. Great tool to have if you ever plan on working on your own car at all.
Old Nov 18, 2012 | 12:50 PM
Ednica87's Avatar
Did you go with the ebay part or find something different? i found a website www.infinitipartsonline.com has anyone used this website before? I found the sensor one here for about $150.00
Old Apr 24, 2018 | 12:42 PM
alvarjaime's Avatar
Hi all. I am trying to change the Yaw Sensor as well but cannot get to it. I removed I believe all the screws but the cover will still not come off to get to the sensor. The gearshift cover I was able to remove but the Yaw Sensor is still covered and I cannot remove that cover. I looked for youtube videos and can not find anything on how to get to the Yaw Sensor, only after the cover has been removed. Any help or advice or redirection is greatly appreciated. I don't want to pay someone over $100 to install something that can be done in under 5 mins. Thank you for your help.
Mry
Mar 3, 2023 01:03 AM
Ednica87
Sep 5, 2015 02:59 AM
Wayne9011
Aug 17, 2015 01:24 AM
Wayne9011
Jul 27, 2015 11:25 AM
newg37
Jul 26, 2015 09:32 AM
