overheat caused by the ac
Old Jun 24, 2011 | 11:30 AM
lazychina123's Avatar
Hi, people, i have the 2004 g35 with 100000 miles. Recently it gets overheat whenever i turn on the a/c no matter i drive in traffic, local or highway.
I get confused if the car in traffic or local and it gets overheat when the a/c is on, that would be caused by the fan. but my car get overheat in highway( i drove 60mph) when the ac is on. when the a/c is off, the needle in tempe gauge goes back to the midd-line. the temperature here in new york is 83F
the two fans seem run very normally
any idea? thermostat ? or the water pump ?
Old Jun 24, 2011 | 12:16 PM
Mustang5L5's Avatar
When was the last time you flushed the coolant? Also, do you know the condition of your radiator?
Old Jun 24, 2011 | 04:37 PM
radiator seems ok, the last time i flushed the coolant is 3 yrs ago
Old Jun 24, 2011 | 04:41 PM
PAIXAO's Avatar
^^ Time for another flush.
Does the car overheat when just sitting? I would let the car sit in the driveway and run it until the fans come on. Obvious places to look you already stated but your radiator could be going.
Old Jun 24, 2011 | 04:43 PM
teahead's Avatar
Does the electric fan kick in at all?
Old Jun 24, 2011 | 04:47 PM
faiz23's Avatar
It could be your thermostat or the fans for the radiator. I would make sure both fans turn on when the AC is on and both of them are free and not binding or have any heavy resistance. The warranty was extended for Coupes but it could also be something that affects you.
https://g35driver.com/forums/5867679-post18.html
https://g35driver.com/forums/engine-...g-issue-2.html
Old Jun 25, 2011 | 06:55 PM
i turned on the a/c and let the car stop at my driveway, both fans run very strongly. my car get overheat again even in highway when the ac is on, i am going to replace the themostart, should i use the oem or other party , thank you
Old Jun 25, 2011 | 07:01 PM
PAIXAO's Avatar
You will be fine with a Nissan thermostat.
Old Jun 29, 2011 | 01:31 PM
i just flush the coolant and replace the thermostart, but the problem is still there. when the tempe goes up i mean the needle at "H", the engine has a higher rpm, then i heard a "click" sound from the hood, and then the tempe dropes back to the normal, just wonder is it something wrong with ECT sensor or other senosr? or even the water pump
thank you
Old Jun 29, 2011 | 01:46 PM
PAIXAO's Avatar
Did you burp the coolant?
Marlin84
Apr 1, 2020 12:52 PM
dcsbh1
Oct 1, 2015 03:15 PM
aaron3719
Sep 29, 2015 10:12 AM
Jay123
Sep 28, 2015 08:42 PM
