How much for new A/C unit?
Old Jun 30, 2011 | 01:29 PM
digitalgulby's Avatar
So I'm pretty certain that the A/C unit on my car has had it. When it turns on, there is a loud clunking engagement noise as it turns on. When the weather is about 80, the A/C unit struggles to operate, intermittently blowing hot air, and occasionally causing the temp gauge to spike to 60-70% (normal is 50%).
If it's 90 like it is today, it usually doesn't work at all. On the freeway it works OK, but city driving causes it stop working and overheating the car.
I get pretty anxious about running the car hot, so I generally avoid using it if I can. But I don't like showing up for appointments all sweaty, so I gotta fix it.
Anyone replace their A/C unit? What does this repair usually run?
Old Jun 30, 2011 | 01:32 PM
infinitig35's Avatar
How do you know it's your AC unit? Take you car to an Infiniti dealer and let them check it out for you. Their trained technician will tell you what's wrong with your car.
Old Jun 30, 2011 | 02:13 PM
Mustang5L5's Avatar
You mean compressor?
They all clunk when it turns on, mine is pretty loud. Been this way since new and still blows cold.
Have a certified HVAC tech look at the car...could have a minor leak that requires a simple o ring replacement and rechanrge
Old Jun 30, 2011 | 05:35 PM
Well I took advice from another thread here and power-washed the condenser, and it did make a large improvement, A/C blows cold now and no overheating. Still runs loud as hell but I guess I don't really care as long as it works.
Old Jun 30, 2011 | 05:48 PM
Mustang5L5's Avatar
It's gonna be loud. E-fan plus the compressor clicking on and off make a he'll of a racket under the hood.
Sounds like your issue is cooling through the condensor/radiator and not so mich a compressor issue.
Old Jul 2, 2011 | 04:59 PM
vanvalks's Avatar
What was the other tread you found the advice on? My 2003 G35 Sedan is having the exact same problem as yours was with the a/c not working in warm temps and the car overheating.
Old Jul 2, 2011 | 07:25 PM
Mustang5L5's Avatar
Hmmm..seems to be a pattern here. Last month or so there have been a lot of these threads and it seems they are all made by 03/04 owners
Old Jul 7, 2011 | 04:21 PM
87 degrees and 90% or higher humidity and the A/C runs great. Everyone should try this before they go to their garage and have them fix the wrong thing!!
Old Jul 7, 2011 | 04:31 PM
vanvalks's Avatar
How were you able to get a good shot at the condensor without taking it off?
Old Oct 10, 2011 | 03:18 PM
Gshroom's Avatar
i would like to know where the condensor is located. could someone please show a picture? my AC turns on but no cold air is coming out
Old Oct 10, 2011 | 03:39 PM
Mustang5L5's Avatar
Condenser is the silver "radiator" in front of the real radiator. Pop the hood and look down thru the hole where the latch is...can't miss it.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
suby01
Not G35 Related
May 25, 2016 03:07 PM
Oregon13
Audio/Video/Electronics
Mar 1, 2016 12:06 AM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
