mystery engine compartment rattle...help
So here's the issue. I usually hear this "rattle" right after i shift into 2nd gear and at low rpm's. 06 6MT sedan.
Also, when i shut down the engine with the clutch out the rattle occurs. However, if I leave the clutch in when i turn it off, the engine shuts down real smooth and quiet.
53K miles on car. Any information would help. Thanks in advance
Do you hear it at idle with the car in neutral? If yes, and it goes away when you depress the clutch pedal, it could be the throwout bearing rattling. Not a major thing, just annoying. My old Monte did that.
The noise is very common for the G and Z 6MT cars. It's a very noisy and vibration-rich transmission.
Do i need to be worried or consider getting the throwout bearing replaced?
I wouldn't really worry about it. Usually that bearing gets replaced when it's apart for a clutch job, so it may make noise for a while but will probably work just fine until then. Like I said, the old one rattled in my Monte for years and never gave me any trouble.
Freeman186
Sep 6, 2023 10:07 AM
