Opinions..
Opinions..
So I'm in the market for some 19's and I found a set that I like.. They come in 2 different offsets though and I'm not sure as to which ones I wanna grab..
I have an 05 Sedan and am lowered on TEIN Basic Damper Coilovers. The sizes of the wheels are offered with 2 different offsets:
front: 19x8.5 offset 38 or 15
rear: 19x10 offset 42 or 20
Just want some opinions on as if I should go with the lower offset or stick with the higher one. What do you guys think?
I realize all of this.. Asking opinions on what offset people think look better here before i purchase the wheels..
Right on... You don't think the wheel size and lower offset will make the sedan look to aggressive? I know people go with a 0 or negative offset, and 20 isn't really that low, but on a 10" wheel in the rear would it stick out to much or still sit pretty flush with the car?
Check out this thread, lots of good info here:
https://g35driver.com/forums/media-s...tch-sedan.html
There have been very few Sedans that have run a 0 or negative offset and only 1 static one that I can recall.
A 10 +20 will stick out past the fender a bit, you will have to stretch a 245 for it to fit properly.
Here is a 10+20 rear on a Sedan:
Johnnyone
And he dumped it for a short period of time:
Johnnyone
vitaliylats11
May 23, 2012 12:34 AM
vitaliylats11
May 22, 2012 09:50 PM
pinkpanther
14
May 16, 2011 05:16 PM
