anyone done a brembo caliper upgrade?
Old Sep 4, 2011 | 11:32 PM
funnyscreenname's Avatar
i know some of the g's came with brembo calipers and all and i'm wondering if i happen to get my hands on a set could i swap them onto my 05 sedan without any hassle? would it be a direct swap? what all would i need for it to be done? anyone on here done this and if so was it a noticable difference? any pics? just wondering because i plan on doing my usual multiple junk yard runs when it cools down and if i came across any brembo calipers i'd like to grab them. any input is appreciated and when i do decide to make my run to the yards i'll make a post seeing if anyone else needs anything. right now i just plan on grabbing up all z tubes, oem hid's, aftermarket parts, and any other parts i can flip for quick cash. anyway, any input on the brake question is appreciated.
Old Sep 4, 2011 | 11:34 PM
CandlestickPark's Avatar
ill Sedan
Yes OEM Brembos from the Coupe are a direct swap on the Sedan, a bunch of Sedans have done this mod.
Old Sep 4, 2011 | 11:35 PM
ill Sedan
Old Sep 5, 2011 | 05:02 AM
psycobusa's Avatar
To do the swap you need the calipers, rotors, brake lines, and rear caliper mounting bolts. Also you'll need to trim or remove your stock rear dust shields.
Old Sep 5, 2011 | 07:59 AM
NjMatteSedan's Avatar
Noone's done it
Old Sep 5, 2011 | 12:33 PM
Are those blue brembos oem or aftermarket or did they paint them? I've only seen the gold colored calipers.
Old Sep 5, 2011 | 12:35 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
They were painted by the owner of the car and installed by myself. As well as the Brembos on the red sedan.
Old Sep 5, 2011 | 01:31 PM
Well I'll be sure to give you a call when I find all the parts. You can come help me with mine. I'll even buy the beer.
Old Sep 6, 2011 | 01:56 PM
5150DS's Avatar
^ Please?
Old Sep 7, 2011 | 04:23 PM
Mustang5L5's Avatar
technically you need to swap the MC as well since the bore diameter is different due to the fluid volume requirements of the Brembos...
However nobody does it
Old Sep 9, 2011 | 01:34 PM
supreme1911's Avatar
Originally Posted by 5150DS
^ Please?
About your sig, are u a law enforcement officer? If not it is truly hilarious hahahha!
Back to topic, will there be any fitment issues such as the rims not fitting on due to the brembos? Are the calipers and rotors the same size as the stock ones?
Old Sep 9, 2011 | 01:38 PM
black_gst's Avatar
I just saw his sig too, im pretty sure hes a cop, i have never seen composite seats in a regular crown vic lol
Old Sep 11, 2011 | 11:03 AM
acr's Avatar
acr
Stock sedan wheels won't fit. Sport 18s may fit, but a spacer would definitely be required. I'm sure others can chime in on this. The rotors are larger than 03-05 brakes. The issue, however, are the calipers. They're much larger and stick out further, requiring a wheel that will clear them.
Old Sep 12, 2011 | 01:04 AM
6spSEDANFTW!'s Avatar
No.
Old Sep 12, 2011 | 03:35 AM
G SEDAN's Avatar
you talk as if it will be an honor. How about you pay the man and he MIGHT make time for you
