Door panel vinyl sliding down
Old Sep 6, 2011 | 03:26 PM
nytevizion's Avatar
I have two questions about the interior of my 04 G35 Sedan.
The driver side vinyl is drooping down below the plastic piece as the image shows below. Has anyone come across this problem and is there any way to fix this? If I take the door panel off will I be able to see this from the reverse side? I thought about cement but there is sticky foam on the back of the vinyl and it would seem that gluing it would probably fail since I would be gluing to tacky foam. I can tuck the vinyl back up with a credit card and it holds for a few days but eventually droops back down.
Also, the handle cover is cracked near the bottom. Does anyone know where to get this replacement for a decent price? I’ve looked around on the net but companies use different names for the piece and I’m afraid to buy the wrong part.
Old Sep 6, 2011 | 03:40 PM
EDW1NK's Avatar
i have the same exact problem with my door too. i peeled back a little bit more and used some glue to put it back in place.
Old Sep 6, 2011 | 04:04 PM
Happy_buddha's Avatar
I had the exact same issue with my 05, took it to a trim shop and they fixed it. Felt like a jackass when they charged me $20 to use a heat gun and some glue, but it's held...
Old Sep 6, 2011 | 04:07 PM
nytevizion's Avatar
Ok, that sounds promising. So how far did you peel it down? An inch or less/more? What type of glue did you use? My vinyl is drooping all the way across the entire seam.
To Happy: They just used a hot glue gun?
Old Sep 6, 2011 | 04:33 PM
It wasn't a hot glue gun so much as upholstery glue cured by heat. The heat gun was one of those beasts they use to peel wall paper...
Old Sep 6, 2011 | 04:45 PM
007JD's Avatar
you have pm about the door handle part
Old Sep 6, 2011 | 04:52 PM
007JD's Avatar
or if anyone need that door handle trim / piece let me know
got 1 for sale ...
its the drive door side
Old Sep 6, 2011 | 05:00 PM
Jeff92se's Avatar
Red Card Crew
Anyone use spray adhesive? How do you get it on there w/o getting it all over the place?
Old Sep 6, 2011 | 05:17 PM
nytevizion's Avatar
Ahh they used it for curing the glue. I know nothing about car interior. If I can't replace it, I'm clueless; plus I don't want to create more problems down the road.
I will probably drive this car until it falls apart, sort of like an on going project.
Old Sep 7, 2011 | 12:25 AM
kr33p's Avatar
i used super glue on mine. it was peeling horribly before, now its starting to peel again! ahhhggghh! im thinking of just removing the entire door panel and removing that vinyl junk and wrap it with some suede!
has anyone done this? wrapped it in suede?
Old Sep 7, 2011 | 01:03 AM
DR.D69's Avatar
just use some 3M glue (it was the white and red tube i think) and apply it to the back of the vinyl and leave some blue tape on it overnight...i did that with mine and its held fine
Old Sep 7, 2011 | 08:15 AM
NjMatteSedan's Avatar
I had the same problem. Spray glue works great. Just use masking tape to mask off whatever you dont want to get sticky with glue
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
dcsbh1
Oct 1, 2015 03:15 PM
itgogitrev
Sep 23, 2015 07:08 PM
toadfire
Sep 21, 2015 07:15 AM
