She wont start!
Old Oct 7, 2011 | 06:24 PM
saliaga08's Avatar
Exclamation She wont start!
Okay so I replaced the clutch on my g35 6mt sedan, followed direction by direction, had pictures taken of the process so that I knew what went where but it the girl just wont start... I don't know if there is a trick to it or what but if anyone has ran into a similar problem and/or knows a solution It would be greatly appreciated!
Old Oct 7, 2011 | 09:10 PM
Mustang5L5's Avatar
Won't start As in cranks and cranks but won't fire?
Or it won't crank over at all?
Old Oct 7, 2011 | 09:22 PM
faiz23's Avatar
did u line up the little dowel little thing on the flywheel
edit:
http://my350z.com/forum/forced-induc...h-install.html
Old Oct 7, 2011 | 09:53 PM
redpearl99's Avatar
^that shouldnt matter
even if the transmission isn't lined up correctly the engine should still crank over
Old Oct 7, 2011 | 09:58 PM
rozhenko's Avatar
u might of messed up the crank sensor if u didnt pull it out before taking off the tranny. if u did pull it out, make sure its in and connected properly.
Old Oct 8, 2011 | 01:34 AM
saliaga08's Avatar
Yes it'll crank but won't fire.
I'll check the sensor tomorrow.
I'll keep you all updated.
Thanks g's.
Old Oct 8, 2011 | 06:35 AM
Blue Dream's Avatar
I drove ttrank's car solo
Def let us know.
Old Oct 8, 2011 | 07:36 PM
1SlowSedan's Avatar
Look for a dot on the sides of your flywheel. When you install the flywheel, the crank position sensor should be right on it.
Old Oct 9, 2011 | 10:40 PM
saliaga08's Avatar
It was the crank sensor, I didnt tighten it enough I suppose.
Thanks G's!
Old Oct 10, 2011 | 12:32 AM
Chief.Crappin.Squirrel's Avatar
glad to hear its working! these peeps almost always point you in the right direction
magnetism80
Feb 1, 2019 10:00 AM
Rhinos7777
Sep 6, 2015 05:36 PM
Jnm07
Sep 5, 2015 01:16 AM
Gwhut?
Sep 4, 2015 11:10 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
