Issue i need help with, id really appreciate it
Old Oct 9, 2011 | 03:19 PM
VincenzG35's Avatar
ok so lately i,ve been driving and hearing a clicking noise or tapping noise when im driving at first it was really just when im a 50 mph road or so, but as of today from when i started my car until it stopped the noise occured.
so heres my Dx and things ive done it doesnt sound like my suspension its coming from the middle of the car (not my engine) but i checked
- checked my heat sheilds
-my LCAs are new so not the bushings ect...
-checked the knucle above the tire no noise
- compression rods are fine no noise from them
- i have a blown shock that makes an odd noise but its not that(bought coils waiting to install)
it only happens when moving and as i increase speed the noise gets faster. truthfully it sounds like when you get out of your car and hear the exhaust tapping the noise is identical and it comes from the middle just like it would you say it's an exhaust leak?
ive only scraped the pipe once on an extremely steep driveway. has anybody had this issue would this explain why my car feels like it has no power when going from a stop?
im replacing my spark plugs tuesday so i should get a lil more power back. and help make things a little bit clear.
any insight or help on the issue would mean alot to me
Old Oct 9, 2011 | 04:27 PM
supreme1911's Avatar
Is your car automatic or Manual?
Have you checked your oil? Also, are you sure its not an engine knocking sound? Because it doesnt sound like the usual things (suspension, rattling exhaust, etc). Since you are losing power too it automatically points to the engine. Next thing Im thinking of is output shaft bearings....
Old Oct 9, 2011 | 08:01 PM
VincenzG35's Avatar
Oil seemed fine ill double check tho and I'm positive its from inderneath nothing whatsoever coming from the bay
Old Oct 10, 2011 | 12:34 PM
VincenzG35's Avatar
Oil was good and losing power might have beeen too strong to say the car just feels a little weaker on take off from a start
Old Oct 10, 2011 | 12:50 PM
artsVQ's Avatar
could be a axle or bearing
Old Oct 10, 2011 | 12:57 PM
VincenzG35's Avatar
How can I check
Old Oct 10, 2011 | 01:39 PM
artsVQ's Avatar
easy way to check to see if its the rear axle is to put someone in the back seat tell them to stick the head out the window if they hear clicking from any of the rear axles then there could be your problem
sometimes axle just need to be greased up and other time just need to be replaced
Old Oct 11, 2011 | 11:25 AM
VincenzG35's Avatar
Ok so I stuck my head out like a golden retriver and nothing from the rear it happens when I tuern the wheel like on a fair turn I hear a click then it starts when I'm in motion
G35Rican
Jul 31, 2024 01:37 AM
yosip1115
Sep 9, 2015 03:30 PM
socaldavid
Sep 5, 2015 04:35 AM
kevintandmd
Sep 3, 2015 06:41 PM
UT G35
Sep 3, 2015 03:58 PM
