Tune or No Tune?
Old Dec 20, 2011 | 06:21 PM
SuperTrooper699's Avatar
Tune or No Tune?
I got a 03 sedan i don't think its a revup model. its a 5at
i don't have a ton done to it, z tube pop charger, art pipes, coupe middy,
3.5vsld swap.
Would it be good to get a tune or would i really not see much out of it?
Also would any performance shop do tunes or can you buy your own tuner?
I've herd that resetting your ecu would actually tune itself with bolt on modifications i don't know much about tuning.
Old Dec 20, 2011 | 09:40 PM
6spSEDANFTW!'s Avatar
No tune, waste of money (but thats just me)
Old Dec 20, 2011 | 10:16 PM
srv2nv's Avatar
G35 Sport
Unfortuantly there isn't a way to tune your ECU anymore now that TS isn't doing them anymore. Your best bet would be to pick up something like the Apex'i AF-C NEO to correct your Air/Fuel ratio since you're probably running a little lean.
You'll probably have to bring the car to a tuning shop to have it properly tuned since any mess up could possibly destroy your engine.
Old Dec 20, 2011 | 10:28 PM
artsVQ's Avatar
Osirus has a ecu upgrade you can do... but its not worth it with the parts you have right now... buy some more parts then do a tune after you have all the parts you want
Old Dec 20, 2011 | 10:57 PM
Michael Joneser's Avatar
I think you need to do some research on here, the answers are all over this forum. I don't think any 03 had the rev up. Don't think you would necessarily need the tune but you would see a power increase from it. Search
Old Dec 20, 2011 | 11:34 PM
sonicii's Avatar
I wouldn't worry about it with the mods you have done, as others have said, you would probably need an aftermarket ECU, or at least a 'piggy back'
The gains would be minimal for the $$ you would spend as you haven't really changed anything to cause the factory tune to be unsuitable.
Also, I don't think the rev-up engines appeared until the 2005+ models.
Old Dec 21, 2011 | 12:46 AM
Songle6MT's Avatar
05-06 sedan 6mt= revup
05-07 coupe= revup
Old Dec 21, 2011 | 12:51 PM
srv2nv's Avatar
G35 Sport
03 didn't have the rev-up. Besides that, he's an 03 with a 5AT...most likely a grey connecter ECU, therefore you belong in this thread...
https://g35driver.com/forums/tuner-d...technical.html
Old Dec 21, 2011 | 02:35 PM
Invictus_Caelumfunis's Avatar
no tune. more research...now go along your way, happy holidays!
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
Usman Ali
Oct 4, 2015 08:23 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
