Love my almost new "G"
Old Jan 26, 2012 | 05:10 PM
Badpreston577's Avatar
From: Fairfax County, Va (just outside Washington DC)
I bought an Infiniti G35X with about 67k on the odo from carmax. The car was test driven on of all days a rainy day. The ride was inpressive and the handling great. I have test driven others in my class the Lexus IS, BMW 3 & 5 series, Mercedes c class even some american cars Camaro and Mustang. The 2006 even drove (in my opinion) better than a newer 2008 G35x. I love the combination of sporty ride and luxury. Though based on a 350z/GT350 Skyline the american interpretation was well thought out and a home run. I love pressing the petal and listen to that engine roar.Who says japanese cars have no personality? This car is a shogun assasin! I don't plan on any mods except for an upgrade of the stereo, cold air intake and exaust work. BTW anybody got any idea where i can find some factory wheels (cheap) i want a seperate set of wheels for the winter.
Old Jan 26, 2012 | 05:17 PM
01yellowr's Avatar
I feel the same way about my 04, as for the wheels try craigslist.
Old Jan 26, 2012 | 05:56 PM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
Check the Private Clasifieds in the marketplace for wheel and tire options, run your stocks in the winter and pick up a set of OEM 19's for the summer. They usually go for $600 - $800, maybe you can get lucky and get tires with them. Cold air intake is pointless as it does absolutely nothing and in some cases a loss of hp & tq. Instead swap out to a Rev-Up airbox, K&N filter, Z-tube and a Motordyne Plenum Spacer. The exhaust HFC, HR Y-pipe and Coupe Mid-pipe to bring out the VQ note, the OEM system is very efficient, but can be tuned to be better. Something to go along wih the OEM 19's is a Z-drop, it will lower your X about 1.5" and will still allow you to come close to spec on the OEM camber arms and toe bolts.
Even with all the OEM mods, you will probably spend about $1,500 maybe less if your patient. Enjoy your G and Happy Modding, just remember to keep it classy.
Old Jan 29, 2012 | 10:06 AM
snowtrax's Avatar
Old Jan 29, 2012 | 01:37 PM
supreme1911's Avatar
+1 agree with everything except the Z-drop with springs. IMHO save for coil overs instead! SOOOO many owners regret getting springs and wished to saved for the coil overs in the first place.
Old Jan 29, 2012 | 01:56 PM
re-crue13's Avatar
He did say cheap wheels, I just assumed a cheap drop also with no need for aftermarket camber arm cost.
Old Jan 29, 2012 | 07:03 PM
05g35dy's Avatar
I would also save for coilovers
Old Jan 30, 2012 | 09:15 AM
Bastone's Avatar
Don't waste your money on an HR Y-pipe and coupe midpipe.
HR Y-pipe isn't so different from your existing Y-pipe (front diff clearance), and if you swap out to a coupe midpipe, you may save 25lbs, but the exhaust note will not change at all.
Best of luck with the car.
Just enjoy it!
Old Jan 30, 2012 | 09:18 AM
infinitig35's Avatar
Old Jan 30, 2012 | 11:59 AM
Songle6MT's Avatar
Just enjoy it!
The HR-Y does promote some benefits, not significant but some. Also the coupe midpipe does alter the sound of the exhaust (smaller resonator).
Old Jan 30, 2012 | 12:25 PM
The HR Y pipe and coupe mid coupe helps a lot used together helps quite a bit. The stock Y pipe has a lot cotton and padding on the exterior of the pipe. It takes away some of the sound. After market y pipes dont and they are a tiny bit louder.
The coupe midpipe really improves low rpm sound. After maybe 3.5k rpm it sounds the similar. You will get drone though.
But what does make a large difference in sound are test pipes and HFC.
Old Jan 30, 2012 | 01:28 PM
Bastone's Avatar
05 G35x Y-Pipe
RWD DE Y-Pipe on the left, 350Z HR Y-pipe on the right
Not much of a difference.
Old Jan 30, 2012 | 01:48 PM
Songle6MT's Avatar
Ahh I forgot about the x y being similar to the hr y. But regardless coupe mid pipe is still beneficial.
Old Jan 30, 2012 | 02:57 PM
Oh yeah u got an AWD. Its pretty similar to the HR. Didnt read that part of the post.
Old Feb 2, 2012 | 11:53 AM
Cheap meaning that i don't want new or refurbished wheels just some used factory wheels that i can put winter tires on. I'm often finding wheel quoted above $200 or more apeace not including any rubber. Considering my car is over 5 years old i thought a little less expensive to aquire some wheels.
KruZZe
Feb 27, 2023 05:04 PM
Marlin84
Apr 1, 2020 12:52 PM
dseet
Oct 11, 2015 12:40 AM
TurTLe*
Sep 29, 2015 01:43 PM
corynooooo
Sep 26, 2015 10:54 AM
