Splashing sound
Old Jan 2, 2005 | 06:08 PM
mongolwarrior's Avatar
Splashing sound
Recently, the past few weeks I noticed splashing sound when the car is in motion. My car is an 03 (1st edition). I took it to the dealership they said it is the brake fluids doing that. I don't think so due to its "larger volume of fluid" sound.
Any help?
Old Jan 2, 2005 | 06:33 PM
Msedanman's Avatar
O.F. Administrator
Any help?
I don't see how it could have anything to do with brake fluid.
The only thing I can think of that you may here is gasoline slopping around in the tank.
Unless someone left a 1/2 bottle of water in the back somewhere.
BTW-- Welcome and g/l with your issue.
Old Jan 3, 2005 | 01:11 AM
splash
the sound appears to be coming from the engine just in front of the driver.
It's like a jug of water in the engine bay. I pop the hood and I don't see any
wet spot or signs of any liquid.
Old Jan 3, 2005 | 11:06 AM
doogie's Avatar
That's 3.5 liters of power slopping around.
Old Jan 3, 2005 | 11:59 AM
G35/SR71's Avatar
Any help?
It may be the evaporator for the AC. Does it sound like a waterfall on the passanger side under the dash? I had Blazer that had a similar problem. It gets clogged up. If so, you will need to have the system flushed. It took several times before the problem cleared up.
Old Jan 3, 2005 | 04:48 PM
G35/SR71's Avatar
If your right, Infiniti need to top it off to 4.5 liters to stop the slopping noise
Old Jan 3, 2005 | 05:03 PM
jstwong's Avatar
How about the windshield wiper fluid reservoir [though it is on the passenger side I believe]?
Old Jan 3, 2005 | 05:17 PM
g4ian's Avatar
Any help?
I have the exact same thing happening in my car. It seems to happen with accelerating from a stop (most noticeable). I plan on mentioning it next time I take the car in...
g4ian
Old Jan 4, 2005 | 02:07 AM
That's it accelerating from a stop that's when it is reproducible.
Is there a TSB on it?
Dallsinghjr1
Sep 17, 2023 11:25 AM
Marlin84
Apr 1, 2020 12:52 PM
Video Share
Jan 31, 2017 04:00 PM
dcsbh1
Oct 1, 2015 03:15 PM
