Alignment Readings(Pic) Need assitance
Old Apr 18, 2012 | 01:26 PM
Picture.g35's Avatar
I have received my alignment reading from firestone. Im trying to figure what camber kit I am needing at this point.
[IMG][/IMG]
eibach sedan pro kit
[IMG][/IMG]
Old Apr 18, 2012 | 06:15 PM
Bump anyone?
Old Apr 18, 2012 | 06:26 PM
NorthDakota's Avatar
its really not that bad. you should be fine. a lot of sports cars come with the camber you have already. if you "need" to be in factory specs then you need a front and rear camber kit. (with toe bolts)
Old Apr 18, 2012 | 06:41 PM
DrewDrew's Avatar
You def want to get that rear camber back in spec, or at least even on both sides. WIth the rear camber kit, you'll get toe bolts as well - they might not be needed at this point with such a mild drop, but could provide useful in the future. Stock bolts tend to slip and turn after awhile.
Front camber is up to you. I love being within oem specs and even on both sides (which isn't possible with a spring drop and non-adjustable front upper arms.)
After a week the springs might settle and even out the camber, but no guarantees. You'd be fine without a front camber kit and flip the tires every 5k miles. That toe front and rear really needs to be brought back into spec though.
Old Apr 18, 2012 | 06:58 PM
BTW why did you get your specs and not have them change anything? stock toe bolts have some adjustment and would save you tire wear and some gas mileage
Old Apr 18, 2012 | 07:47 PM
I wanted to get the alignment check first to figure out what camber to get then order them, then get the alignment
Old Apr 18, 2012 | 07:52 PM
Makes sense... kinda... did they charge you as much as if they changed anything? when I dropped my sedan I got a 3 year alignment and it was the best choice I made with my car. paid for itself already.
Old Apr 18, 2012 | 07:53 PM
Yeah I'm gonna get coilover in a few months. So I'll dart off by getting the spc rear camber kit
Old Apr 18, 2012 | 07:57 PM
Nope paid nothing for the check, here they offer lifetime alignmnet for 179😊
Old Apr 18, 2012 | 08:02 PM
^Jealous. haha. SPC is good stuff. get the front too IF you can stand the price.
Old Apr 19, 2012 | 05:19 PM
GreenPenguin's Avatar
OP, your toe is atrocious! That is what will wear your tires to shreds. Your camber specs are actually pretty decent. A little camber wont affect much. I have close to -2.0 degrees of camber in front and rear and 8 months later, have no unusual wear patterns whatsoever. Im dropped on 350z Tokico DSP9's with 350z Tein S-techs with no kit at all.
Old Apr 19, 2012 | 06:59 PM
Thanks for the info man, I just orderd the eibach alignment toe and arm kit rear just to be safe since I plan go coil in summer
Old Apr 19, 2012 | 07:30 PM
Blue Dream's Avatar
I drove ttrank's car solo
Hey man it was good meeting you last weekend. You've received some good advice here but if you have any other questions feel free to PM me.
Old Apr 19, 2012 | 07:31 PM
thanks very helpful appreciate it
Old Apr 19, 2012 | 07:35 PM
Thanks man it was good actually meeting someone from the forum. I ll make sure to pm with questions lol
skippyG
Jan 25, 2016 01:18 PM
itschuckster
Jul 25, 2015 08:07 AM
Soumilg
Jul 23, 2015 09:26 AM
beevanhuynh
Jul 23, 2015 01:37 AM
