extended warranty questions
Old Apr 21, 2012 | 12:43 PM
petersonxc825's Avatar
Angry extended warranty questions
hey guys,
i just got a 2004 g35 sedan, and the previous owners had an extended warranty. i sent the paper work into transfer the warranty into my name, but then my car has been going into limp mode and giving error code p2135(?), something about the TPS. anyways, the infiniti rep at the service department says i have to wait 60 days before i can use the warranty. is that normal because i think it is stupid,and if my car was non functional i would be without a car for 2 months which is insane.
Old Apr 23, 2012 | 09:42 AM
GraphiteGSdn's Avatar
Assuming this is the Infiniti Elite Extended Protection Plan you have, why don't you contact consumer affairs directly to verify what the dealership is telling you?
800.662.6200
8:00 a.m. - 5:00 p.m. Eastern / Central Time / Pacific Time
Monday through Friday
8:00 a.m. - 3:00 p.m. Central Time
Saturday
Old Apr 23, 2012 | 10:50 AM
i actually emailed them over a week ago, but they still haven't replied. i guess ill try calling them, thanks.
Old Apr 23, 2012 | 03:41 PM
Philly_G35's Avatar
I know you don't want to pay out of pocket for something covered under warranty, but it is a simple fix. If the code if for the accelerator pedal position sensor you need to swap out the whole pedal assembly. I think I paid $130 for the part and it took about 15 minutes to swap out the parts.
edit: If you search the site you will find procedures to reset the sensor which is done simply by turning on and off the key and pressing the gas pedal is a specific sequence. It might be worth a shot to see if it fixes your problem.
Old Apr 23, 2012 | 04:06 PM
It's the throttle position on the throttle body, not the pedal position sensor so i would have to replace the whole throttle body, and that's a bit more expensive.
Old Apr 25, 2012 | 08:14 AM
hg35x's Avatar
I had the P2135 code and it was the accelerator pedal position sensor, not the throttle body.
Old Apr 26, 2012 | 12:46 AM
well, im not sure if my code is p2135, i just remember it said that the TPS was sending the wrong voltages. My mechanic told me its the TB
Old Apr 26, 2012 | 01:47 AM
jsolo's Avatar
I don't see anything in here about 60 days, but also don't believe this is the full policy.
https://owners.infinitiusa.com/iowne..._Agreement.pdf
Old Apr 26, 2012 | 01:14 PM
bluedevils95's Avatar
Warrenty is warrenty. They cant do that. Did you call them or try another dealership?
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
