JDM Mirror Goodies
Old Aug 11, 2012 | 03:40 PM
  #181
neo_anderson302's Avatar
I think I found the solution for the bad angle.
Here you go:
Old Aug 11, 2012 | 03:44 PM
  #182
Best idea.
$4.00 fix
Old Aug 11, 2012 | 08:40 PM
  #183
TunerMax's Avatar
G35
Originally Posted by neo_anderson302
Best idea.
$4.00 fix
Already have these but that's far from a fix. It doesn't show anymore because it has the same problem the main mirror does, it only shows the mirror cover inside due to the angle the mirror is on....
Old Aug 11, 2012 | 10:16 PM
  #184
Well I'm glad I didnt buy it.
I'll just deal with it, I modded out with these mirrors. I'm about 100% happy.
I just got to go to the dealer and see there reaction. lol
Old Mar 21, 2013 | 05:34 PM
  #185
MPG35fiend's Avatar
does any body know where i can get the power fold wiring harness?
Old Aug 17, 2013 | 04:49 AM
  #186
blubox's Avatar
Originally Posted by TunerMax
thanks so much for checking that. I'm running mine the same as you now.
JDM on Left (driver side) and USDM on right (passenger side), the fold-in amount is almost dead even, the only viewing angle that is wrong is the Driver side. If we can find a way to correct the driver side viewing angle we're golden, personally I don't see a straightforward way to do that.
Thanks again for posting this is EXACTLY the confirmation I was waiting for before doing a write up.
For our DRIVER side: try JDM base w/ USDM mirror.
Old Aug 17, 2013 | 12:15 PM
  #187
TunerMax's Avatar
G35
^huh? what is a lens?
Old Nov 12, 2013 | 09:35 PM
  #188
blubox's Avatar
I was referring to the Mirrors.
Old Nov 13, 2013 | 12:41 AM
  #189
TunerMax's Avatar
G35
Yes you should be using the USDM mirror/glass on BOTH because the perception or whatever it's called is different side to side.
However this will not change the viewing angle.
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
BfloG35
Oct 16, 2015 05:22 PM
the93owner
Sep 28, 2015 10:37 PM
