JDM Mirror Goodies
Running it through the plug is alot cleaner and safer. Just my opinion. I want my car to look factory and clean.
And you dont need a tool to run through it, but professional I would say its recommend.
http://slap.gotdns.org/SpeakerWireDIY.pdf
Cool beans.
Anyways, although that guy did a great write up, don't do that. That's horrid.
I stopped reading it when I saw this:
"STEP 4: Drill Holes Through the Molex Connectors"
So much for 'clean and OEM'
Ridiculous.POST #36 and POST #38 in this thread are how I did this. Super, Super simple. No drilling a bloody weathersealed connector or any of the nonsense that involves.
I bet you that guy did all that work then realized at the end that there's a hole immediately under the connector that is less than 3" away, and shot himself in the head
i had my JDM signal mirror covers since 2009 and i never had any problems with how i wired it
the wires are not pinching at all they are loose and can move freely
thanks for the info
i got my JDM mirror switch done tonight cant wait till the sun comes up to put it in
By cookiekiller at 2012-07-02
thanks for the info
thanks for the info
thanks for the info
As for the wires, maybe the picture is just deceiving, cause int hat picture they look kinked over a fairly thin edged steel. Anyways it's all good man whatever works for you!
Already fused with the standard tilt power supply unless you ran dedicated power somehow?
Tuner - oh yeah forgot the factory fuse box has one..
Neo - I am using the driver side USDM mirror base
And JDM mirror base on the passenger side
Until I figure out how to make the driver side to fold like that passenger side when the USDM base is on the passenger side
So how far you with the usdm base on the driverside? I saw you sanded some stuff, that wasnt enough to much the two look alike?
Thanks so much for the picture man!
Now we need a picture of how much the JDM base -equipped Right side folds in, and it's viewing angle.
Looks nice, Max. Told bad its so hard to see it when driving. Atleast in my case it is, i have to bend to the side to see the switch.
But all you need to do is turn the steering wheel slightly to see it just fine.
If you want yours to work all you need to do is hook up the ground wire for it to any Illumination Ground.
There's 2 ground wires one is for the switch one for the bulb.
And the bulb might not be any good, dunno, you'll have to check that also.
