Need help with PA15-INFI
Old Jun 8, 2012 | 04:02 PM
jdubin94's Avatar
Alright. So I just got my PA15-INFI. I am really confused. For those of you who have installed it, you know that one of the wiring harnesses to go into the sat tuner in the trunk. The other wiring harness has to go in the back of our head units. What I don't get it is that the two wiring harnesses are right next to each other. Here is a pic.
So ya I don't get it. How is one of those supposed to go in the trunk and one in the head unit when they are connected to each other?
Old Jun 8, 2012 | 04:12 PM
harbtheforcaste's Avatar
do you have the sat hookup in the trunk if you do you can use that if you dont then you have to use the plug for the back of the headunit
Old Jun 8, 2012 | 04:14 PM
jdubin94's Avatar
Don't all of our G's have the SAT hookup?
jdubin94's Avatar
And my mistake, I just called USA Spec, they said that you don't plug anything into the head unit. That makes sense now.
Old Jun 8, 2012 | 04:29 PM
https://g35driver.com/forums/audio-v...15-infi-2.html.... i had to plug mine into the back of my HU.
Old Jun 8, 2012 | 04:37 PM
jdubin94's Avatar
Im so confused.
I found this wire in my trunk. Is this the SAT Tuner?
If it is, I am still confused because I don't have an SAT button on my head unit.
Old Jun 8, 2012 | 04:49 PM
Peoria35sedan's Avatar
That's the SAT connector in the trunk, the PA15 harness plugs in there. I think you use the RADIO button to access your PA15.
Old Jun 8, 2012 | 05:58 PM
Songle6MT's Avatar
Peoria is correct.
You plug the USA Spec unit into the Sat cable in the trunk. Switch the DIP settings to the correct ones. I can't remember exactly what mine are set at.
Then I ran the cable under the seat, carpet and into the center console.
You then hit the radio button and will notice you now magically have an xm1 and xm2 setting
Hope that helps.
Old Jun 8, 2012 | 06:04 PM
jdubin94's Avatar
Originally Posted by Songle6MT
Peoria is correct.
Hope that helps.
It does. Thank you. But is it true that for those of use who do not have the SAT button, the steering wheel track control does not work?
Old Jun 8, 2012 | 06:19 PM
Songle6MT's Avatar
You are correct.
Honestly I just have mine on manual the whole time and control it from the Ipod anyways.
I believe if you have it set up so you cannot do that, the track button works. However, I didn't want to try to figure out all the folders and all that, so manual mode it is lol.
Old Jun 11, 2012 | 10:25 AM
They work but the track advance moves up/down a playlist, artist, album not a single track, The fast forward (left side of deck) moves a single track.
thewinnipegjets
Apr 24, 2014 11:48 AM
Project-G
Audio/Video/Electronics
14
Sep 16, 2011 05:40 PM
VinhFTW
May 10, 2010 06:18 PM
