tires still wearing after front spc camber install..what gives?
so there's my alignment sheet from 02/2010...i remember the guys saying they had to mess with the Toe to align it correctly. Front tires wore mostly on the inside and lasted around 18k miles before i had to replace them..i have around 6k miles on the current set and see some wear on the inside on the front..rear is perfectly fine...probably need to get the alignment done =/
sucks that the shop i went to back in 2010 closed down lol..have to find a new one. idk if i trust les schwab with lowered cars =/
Also I'm confused about the shim placement, does anyone have a nice pretty picture of that?
havent looked at the bushings..but i took my car in to the dealership in dec of 2010 to get my cats replaced under warranty and they did a multi point inspection for free and listed a few things to get fixed..they told me to replace the front left and right ball joints and he said something about the torque arms i believe..let me know if these would effect the tires to wear on the inside..thanks
^^LOL @ op. Yes, worn parts will cause inaccurate/fluctuating allignment and excessive tire wear.
Alright sick, I think I'll do that because I'll want my camber back in the winter. Thanks so much for posting this man, without the video I'd be completely lost.
One thing I reallyd on't get though.... How on earth does the ABS shim work?
The spacers are moving the hub out farther than it's suppose to be. Farther from the ABS sensor. By installing a shim in the ABS sensor, that effectively would move the sensor EVEN FARTHER away, no?
Fast forward to 2:00 in this video and you'll see what part is used to set caster/camber. It's in the same spot/same bolt. The ball joint underneath has an offset threaded bolt on top where the large flat nut threads into. You'll notice if you losen it up that the lower part pivots the arm forward and back. That is what sets your caster. Camber just slides in and out.
Hopefully that makes any sense lol. I can try to find pics etc if needed.
You can also adjust camber without having to remove the wheel on the SPC (I think you can on all aftermarket a-arms IIRC). Just need a big ole 27mm wrench
http://youtu.be/ju4aNFSu41A
http://www.youtube.com/watch?v=ju4aNFSu41A
No problem Matt.
It's been a few years since I've installed an SPC front kit and this all may be shown in the vid I posted but IIRC the kit comes with new backets and special bolts (one is longer with a female threaded section at the top middle of it). You need to use those pieces to get the ABS sensor back into the correct place. There are also additional washers supplied incase you need to back off the sensor some.
FS[Canada]: 19" Rays Volk LE37 Wheels Rims with Falken Tires
netcbc
Wheels & Tires CDN
09-24-2015 09:53 AM
Fireman07603
08-09-2015 06:00 PM
netcbc
Steering & Suspension CDN
07-24-2015 01:59 PM
