Brushed "Aluminum" interior trim
Old Jun 21, 2012 | 09:52 AM
superman22x's Avatar
I just picked up a new g35x. By new, I mean it's an 05 with 148k miles. But it was a decent deal ($6700) and it's in fairly decent shape other than some small things.
One of those small things, is all the aluminum trim, the trim around the shifter, and on the inside door handles. It looks like Iron Man was driving my car based on the thousands of tiny scratches on those and under the driver side exterior door panel. My question is, has anyone attempted to paint these or are there replacements I can buy anywhere? I would think if I wetsanded and polished the pieces, they would lose their brushed aluminum look.
The other small thing is a clunk from the passenger side suspension. Seller claimed it was control arm bushings as that's what Pepboys diagnosed it as. More than likely it's the compression arm bushings though from what I've been reading. Maybe a ball joint? My friend has a pickle fork if I the ball joints are replaceable.
Old Jun 21, 2012 | 10:08 AM
re-crue13's Avatar
OB '04 Coupe Premium w/Performance Wheel & Tire
https://g35driver.com/forums/body-in...pictorial.html
Old Jun 21, 2012 | 10:09 AM
re-crue13's Avatar
https://g35driver.com/forums/g-spot/...er-thread.html
Old Jun 21, 2012 | 11:03 AM
MJION's Avatar
CLUNK - Yep, common problem, lower control arm bushing is shot. You can replace just just the bushing for around $20. However, if the ball joint at the other end is shot then you will need to replace the entire control arm approximately $150.
Old Jun 21, 2012 | 11:14 AM
Thanks everyone. Any thing I can do with the brushed aluminum around the shifter?
I'll look at the control arm bushing. I need some sort of a press for that right? Autozone rents one that works for bushings and U-joints I think.
Old Jun 21, 2012 | 11:38 AM
jmcohen23's Avatar
I recall someone looking to trade his wood trim for the aluminum one... but I failed to pull the trigger on that deal...
Old Jun 21, 2012 | 12:08 PM
My car is an 05, are these trim pieces real aluminum? I thought it was plastic looking at it, but maybe I'm wrong.
Old Jun 21, 2012 | 02:07 PM
VMRWheels's Avatar
Good tutorial! I like how that looks as well.
Old Jun 22, 2012 | 08:08 AM
Infiniti Chica's Avatar
A few people have gone the carbon fiber route, which is weekend project of gluing pre-cut cut carbon fiber onto the trim. Some folks like it: others don't.
Old Jun 22, 2012 | 09:06 AM
I don't like carbon fiber in the interior at all really. My pieces are all aluminum. Not sure why I didn't realize it before. I'm going to sand them and put the brush strokes look back in myself with some 220 grit.
Old Jun 26, 2012 | 07:19 AM
I forgot about the coating on the aluminum. Not sure if the pieces are just clear coated or anodized. I just have to try and find a similar clear coating.
Old Jun 27, 2012 | 09:53 AM
I finished the sanding and polishing yesterday. I used a 1200 grit and 500 grit piece of sand paper to put in the brush strokes. It's difficult with the curve in the trim piece, but I like the result. I'll put some pictures up tonight.
Old Jun 28, 2012 | 11:15 PM
Ziltoid's Avatar
Awesome! I look forward to seeing those pics, I have the same issue in my car
Old Jun 29, 2012 | 01:33 AM
nism0b0y's Avatar
I did the carbon fiber route but I just got the vinyl and wrapped it. You could also find vinyl to do the same thing in all sorts of colors and designs. I just found some snake skin looking vinyl today. The door inserts are aluminum, but can be replaced. The vinyl is easy and it doesn't damage anything when it's removed. Unless you don't prep the surface right the first time then you may end up pulling All the armor all that had been put on things in the past.
Old Aug 6, 2012 | 02:29 PM
Stingray90's Avatar
No pics yet? I'm working on something similar.
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
alessandro
Oct 8, 2015 09:29 AM
itgogitrev
Sep 25, 2015 10:28 AM
