z tube installed with extra vacuum hose
Old Jul 1, 2012 | 10:43 AM
Dr3w5ki's Avatar
Oh, okay. Thanks for the advice bro.
Old Jul 1, 2012 | 10:57 AM
seymore4's Avatar
m56
I never noticed it staying cooler, better idea would be to just delete the coolant line that circulates behind the throttle body. These engine bays get so hot anyways it's really just splitting hairs at this point
Old Jul 1, 2012 | 02:26 PM
Dr3w5ki's Avatar
So regular spacer or ISO Thermal?
Old Jul 1, 2012 | 02:28 PM
seymore4's Avatar
m56
People will debate it till the cows come home but the difference is negligible at best. Get the basic
Old Jul 1, 2012 | 02:32 PM
Shanes_G's Avatar
motordyne should build the spacer right in to the mrev 2.
Old Jul 1, 2012 | 04:18 PM
TunerMax's Avatar
G35
Coolant bypass is a good mod for power.
But it WILL affect cold starts and idle in colder climates. The purpose of this is to warm the throttle body/incoming air to get the engine up to temp faster and ease cold starting.
It does a great job too, and in fairly negligable ways extends the life of the engine. But that portion really is splitting hairs, especially when you're aiming for more HP.
And on the cold start bit, I did the bypass on my Maxima and never had an issue with starting or cold idle - Southern Ontario temperatures.
^This is my personal feeling on it. If you're going for power you're better saving the differnece and buying other go fast goodies. As far as I know all the spacers have low heat transfer qualities, so unless you're getting steel pr aluminum ones, you'll be fine.
Old Jul 2, 2012 | 04:17 AM
Dr3w5ki's Avatar
Regular spacer it is... What's other good mods for hp I can do?
Old Jul 2, 2012 | 12:48 PM
seymore4's Avatar
m56
Depends how far down the rabbit hole you want to go lol
You said you installed a z-tube, did you get a new filter as well? If not pick up a K&N filter, best bang for the buck.
Dont neglect regular maintenance either, New spark plugs are good for around 3 hp as well if they're old.
High flow cats or test pipes of some sort would be the next place to go for gains, followed by an uprev reflash and cat-back exhaust.
Old Jul 4, 2012 | 07:05 PM
supG35x's Avatar
Whats the advantage of having spacer? Do i need it?
Old Jul 4, 2012 | 07:09 PM
seymore4's Avatar
m56
It makes it go faster. cheapest most effective mod you can do for power
Old Jul 4, 2012 | 07:16 PM
supG35x's Avatar
Where would i find one?
Old Jul 4, 2012 | 07:20 PM
seymore4's Avatar
m56
the classifieds, any of the vendors, craigslist, ebay... lol They're very common man, I think 6 or 7 different companies make them. 5/16" is the best thickness for overall power gains, there is no problem with used ones either so if you can find one go for it.
Old Jul 4, 2012 | 07:28 PM
supG35x's Avatar
Sorry for being a newbie but what does that spacer give power? It just looks like a gasket to me lol
Old Jul 4, 2012 | 07:33 PM
seymore4's Avatar
m56
It is a gasket, but a very thick one. It allows more air to flow to the cylinders, and thus more power. Its a defect in the plenum design that the spacer overcomes
EnCr1pt3d
Jul 8, 2019 02:48 PM
R350k5
Oct 1, 2015 08:41 PM
RA102223
Aug 15, 2015 09:24 PM
lemmy999
Jul 25, 2015 12:13 PM
