alignment question
In either case, with a 350Z drop you might be ok, but I'd wager that you'll be running a little bit of negative camber without the spacers installed.
There is a big negative to the spacers I haven't sorted out yet, the ABS sensor reads incorrect. They supply a bracket that is supposed to fix this but I can't see how it does, I might try it anyways before I machine the mounting surface of the sensor down.
Caster IS adjustable with the SPC front kit.
Camber should be to specification or you will wear your tires faster and handling/ride can suffer. From a 'slam it poke it' perspective, sure, set it where ever the heck you want, because handling, ride, and tire wear are no longer high priorities. Just set the toe straight and roll on.
As for your more direct question, the numbers are what some might call signifigantly different, especially considering the car is the same in pretty much all suspension aspects.
G35
350Z
