Tranny grind in 1st/2nd
Old Jul 10, 2012 | 02:03 AM
Jason P.'s Avatar
I noticed my tranny (06 g35x) is grinding under hard accel and it just started prob the last 1k miles. I just did an 8k mile roadtrip and prior I had my mechanic change my tranny fluid.
After reading the forum I am starting to think he didnt use Nissan Matic J as it was reccomended. Should I flush it out as much as I can with the Magic J to see if it fixes the probem?
Old Jul 10, 2012 | 02:39 AM
dineth00i30's Avatar
Bro, its called MAJIC J for a reason..its MAJIC!
Old Jul 10, 2012 | 03:30 AM
thescreensavers's Avatar
Mr.202?
You need to find out what fluid he used exactly, please let us know
They don't make matic-j anymore they replaced it with matic-s.
Old Jul 10, 2012 | 09:36 AM
Jason P.'s Avatar
I just called him. Said they used nissan matic j. Or whatever was reccomended by the factory. Going to bring it by so they can check it out.
Old Jul 10, 2012 | 10:10 AM
Mr.202?
This is Alarming, you cannot find Matic J any more, it hasn't been sold for 2+ years. I mean there could be some stock left over, but its rare. FYI
Old Jul 10, 2012 | 10:38 AM
DaveNYC's Avatar
Do you have TPs or HFCs? Asking because cheaper or poorly installed TPs under hard acceleration will knock against the undercarriage off the line which makes it sound like a grinding but actually wasn't, it was my issue until I changed to resonated TPs.
Old Jul 10, 2012 | 10:39 AM
Jason P.'s Avatar
Well I do trust my mechanic. Hes a good friend. So I hope its not them pulling the wool over my eyes.
I went there and they drove it, could not hear the sound I asked about so then I drove it. Lo behold it didnt want to repeat the sound. Could be a rotten heat shield hitting the pipes but im not sure at this point. Im going to have to check the tranny fluid level to be sure. Otherwise no difference in engagement or performance, just that irritating sound to make you irk.
Btw when should I change out the differentials? Heard it was between 60-100k.
Old Jul 10, 2012 | 11:25 AM
Mr.202?
^ 60k is a good interval, If you are harder on the diff 30k, Its about 1.5 quarts
Old Jul 10, 2012 | 01:01 PM
Jason P.'s Avatar
seems to be one problem after another i have on my hands.
i few days ago i noticed my thermo reading H and my radiator kicking in louder than usual. coolant leaked out the top of the surge tank - realizing this isnt good. i thought it was a loose hose so i clamped it down - drove fine for the last two days and just after my last post i noticed it read H again - same thing all over.
i searched the forum and deduced it can be:
+air in the system
+thermostat gone to ****
+clogged somewhere on the cooling line
+radiator is busted
all seems good places to start except the last - i visually checked the radiator and it looked fine. my car's at 86350 and i had a coolant flush at 77XXX. im really dumfounded.
edit*
hey Dave sorry im still pretty newbie to the Nissan platform (coming from Honda) but im not actually sure with TPs or HFCs are. mine car is completely bone stock.
Old Jul 10, 2012 | 01:23 PM
Mr.202?
+air in the system
+radiator is busted
edit*
TP= Test Pipes
HFC= High Flow Cats
Since you're stock you dont have em.
The overheating issue is semi serious, Dony rely on the gauge, your engine is going to run hot way before it registers H on the gauge. Need to get it fixed asap its probably a simple issue.
Old Jul 10, 2012 | 02:23 PM
Jason P.'s Avatar
Yea im going to change the thermostat and flush out the coolant again to make sure no air is in the system tomorrow night. Hopefully that fixes my problems.
Old Jul 10, 2012 | 03:28 PM
NicooG35X's Avatar
Amsoil has Nissan matic j compatibility I use it for Infiniti here in Pittsburgh.
magnetism80
Feb 1, 2019 10:00 AM
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
bryanr
Drivetrain
Sep 30, 2015 06:31 AM
alinero718
Sep 27, 2015 09:35 PM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
