Engine swap 04 g35x
Old Jul 28, 2012 | 06:53 PM
Rob902's Avatar
Engine swap 04 g35x
I have a 04 g35x sedan and I'm looking to change the engine because of excess oil consumption. I'm wondering if I'm only limited to that years engine or am I able to use a 2005 VQ35 engine as well. I know there's different ratings for coupes and model years just wondering what my options are.
Old Jul 29, 2012 | 01:37 AM
hL.'s Avatar
hL.
It's the same engine. VQ35DE from 03-06. Except for 05+, if it was a manual transmission, then it would have the rev-up version of the VQ35DE instead But it should fit nontheless (although I'd stay away from it since it's notorious for oil consumption).
Old Jul 29, 2012 | 08:54 AM
TunerMax's Avatar
G35
05-06 engine is different, but could be made to work. The block is the same, your transmission will mount up, etc. But the heads, timing case, etc are different.
The 2003.5-2004 have a different ECU than the 2005-2006 though, and I'm not sure you can run them on on-another. I'm sure you could make one work for the other, but might not run ideally without some tweaking.
And then the 2003.0 has a different ECU also, you don't want that one, it's a POS.
Old Jul 29, 2012 | 09:51 AM
Rob902's Avatar
Thanks, i think I'll stick with the same model year
Old Jul 29, 2012 | 10:29 AM
Beef's Avatar
Where are you buying your engine?
Old Jul 29, 2012 | 10:44 AM
Rob902's Avatar
I'm not sure yet there's a site called tiger Japanese, they didn't have anything available right now, but there engines a fair priced, low mileage and cheap shipping. I browsed a few sites but I'm not too sure unless you can recommend any?
Old Jul 29, 2012 | 10:51 AM
JaE35's Avatar
Moderator
G35 Sedan
Isn't that only the case for manual transmissions?
How about using your stock ecu with the swapped engine...
Old Jul 29, 2012 | 11:14 AM
Rob902's Avatar
Ya I don't think the 04 would work on 05.
Old Jul 29, 2012 | 08:08 PM
ccc123pm's Avatar
X
04-06 awd sedans are the same. RWD went to the revup motor for 05-06, but AWD did not.
Old Jul 29, 2012 | 09:08 PM
TunerMax's Avatar
G35
Do you mean the Automatic mounting is different between 03/04 and 05/06?
Old Jul 29, 2012 | 09:41 PM
Rob902's Avatar
I wasn't sure if the ecu from my 04 would work with the 05/06, I thought they Produced more hp and had some minor differences.
Old Jul 30, 2012 | 01:38 AM
nism0b0y's Avatar
so should I change my ecu to an 04 one if I have an 03 with the sport tuned suspension or not bother with the cost?
Old Jul 30, 2012 | 09:21 AM
TunerMax's Avatar
G35
What? the early 2003.0 ECU is different, can cannot simply be changed with the 2003.5-2004 style
Yeah I have no idea if it would work. I do know that they're different. Different heads, different cams, different timing case, different accessory drive setup.
That doesn't mean one wont work on the other, but you're looking for trouble trying to mix them up.
Ideally, you should always get the ECU out of the car you got the engine from. And make sure that ECU is compatible with all your stock Chassis (shell) wiring, harnesses, plugs, etc.
Old Jul 31, 2012 | 11:52 AM
onevoice's Avatar
I recently replaced my 04 35x engine as well due to OC issue (130K mile on it)
The following should work:
Automatic: 03-06 sedan. For coupe (you will have to retain the upper oil pan from your current engine)
Manual: 03-04 (05 and 06 manuals were rev-up and they won't work)
My replacement was from an '05 coupe (30k miles) and I had to retain the upper oil pan from my 04x
Hope this helps!!
Old Jul 31, 2012 | 12:19 PM
JaE35's Avatar
Moderator
G35 Sedan
Really? I could've sworn the engines are the exact same
