Difference between 2003/04 Sedan trunk?
I've been shopping for a 2003/04 G35 Sedan and I was wondering about a different trunk style I've been seeing.
I either see 1 or 2 above. I prefer 1 as it seems like the newer 05/06 style but I'm wondering what exactly it is as I've seen both on 2003 models.
I drove ttrank's car solo
Received 1,487 Likes
on
I am not sure of this info, but this is what I've heard on here:
You will need to wire in a switch for the trunk, becaust the 2003.0 doesn't have one.
the 2003.5-2004 has a trunk release switch by the steering wheel.
the 2005-2006 has a almost-hidden button back by the trunk
But yours has only that latch, if you install another trunk you will need to figure out some kind of trunk release.
Then come back to us and we'll help you spend some more money.
Something else to keep in mind -- the early 03's also had an earlier ECU which is NOT tunable with most popular tuners (Cobb, Uprev, etc., do a little searching here), so if you're planning to get the mod-itis really bad, you should take that into consideration.
Here's a link to get you started:
https://g35driver.com/forums/tuner-d...technical.html
on
TunerMax (07-29-2012)
