more ebay for the 05-06 sedans.. good or bad thing?
Old Apr 25, 2013 | 06:54 PM
  #91
d3zzy718's Avatar
have em installed on my car
Old Apr 25, 2013 | 07:13 PM
  #92
ibg's Avatar
ibg
they look nice.
how much did they cost you ....
were they just plug and play?
Old Apr 26, 2013 | 10:13 AM
  #93
psedog's Avatar
Back in SD**
IBG, yes they are plug and play. When you swap your bulbs, make sure to remove the metal guards that are on them as those are specifically for Reflector housings not projectors. On projectors they just limit light output. As far as the 04 sedan is, I'm not sure. The only ones I could find are these
http://www.ebay.com/itm/2003-2004-In...6cb616&vxp=mtr
Old Apr 26, 2013 | 10:15 AM
  #94
psedog's Avatar
Back in SD**
Never mind, I found these. They look nice.
Link
Old Apr 26, 2013 | 01:32 PM
  #95
BuzzLightYear's Avatar
I'm hoping someone releases a oem style set just with projectors, no black housing and no LED strip. Even if just a dual projector setup, I'd pick up a set in a heartbeat!
Old Apr 26, 2013 | 01:36 PM
  #96
mpugeda's Avatar
very easy to do. if you're interested in a set I can make it happen
Old Apr 26, 2013 | 02:45 PM
  #97
Mustang5L5's Avatar
You mean headlights that don't make the car look like a spaceship??
I love the new LED DRL's (I own a car with a set)....but some of the aftermarket offerings to retrofit this into older models just look.....odd.
Old Apr 26, 2013 | 03:30 PM
  #98
JaE35's Avatar
Moderator
G35 Sedan
Link
i have these on my car, i think they look better than all of the other ones..these also cost quite a bit more IIRC
Old Apr 26, 2013 | 06:43 PM
  #99
NMG-4's Avatar
are they for 03-04 only? or they have an 05-06 model? thanks
Old Apr 26, 2013 | 07:24 PM
  #100
yoyoyo8's Avatar
I like the 03 one but not sure if it fits 05-06.
Old Apr 26, 2013 | 08:23 PM
  #101
JaE35's Avatar
Moderator
G35 Sedan
I believe this model is 03/04 only
Old Apr 26, 2013 | 11:35 PM
  #102
psedog's Avatar
Back in SD**
Yes, that one is only for the 03/04. If you want it on the 05/06, then you will need to get the hood, bumper, and fenders from an 03/04 as well.
Old Apr 29, 2013 | 02:37 AM
  #103
psedog's Avatar
Back in SD**
Stay away from these headlights! My lenses are already starting to crack.
Old Apr 29, 2013 | 09:36 AM
  #104
mpugeda's Avatar
the 05-06 oem reps are legit. I'm in the middle of retrofitting a second set.
Old May 2, 2013 | 12:04 PM
  #105
Megazord's Avatar
damnnn too good to be true
