Sedan projectors...
Old Oct 17, 2012 | 11:49 PM
Dr3w5ki's Avatar
Sedan projectors...
Does anybody know where these can be found? I have an 03 sedan and all I've seen is coupe projectors. :/
Old Oct 18, 2012 | 12:19 AM
dominate's Avatar
You need to retrofit them with projectors from other cars. There are no OEM projectors for first gen sedans.
Old Oct 18, 2012 | 12:24 AM
Jaygotboost's Avatar
buy some headlamps & ill build them for you
Old Oct 18, 2012 | 12:50 AM
DrunkenIronOx's Avatar
Morimoto h1 or d2s for a plug and play installation. No cutting required if you're putting them in the high beam location.
http://www.theretrofitsource.com/
Old Oct 18, 2012 | 01:55 AM
Beebo's Avatar
member r1forever80 can make you a set of sedan projectors.
his name is Stephen, send him a PM
Old Oct 18, 2012 | 04:45 AM
5150DS's Avatar
Are they also pnp for low/fog?
Old Oct 18, 2012 | 11:23 PM
Dr3w5ki's Avatar
PM'd.
Old Oct 19, 2012 | 01:49 PM
They're still plug and play. You just have to cut part of the reflector housing to put them in. A member on here provided pictures on where you need to cut.
Here it is.
https://g35driver.com/forums/media-s...-retrofit.html
Old Oct 19, 2012 | 07:11 PM
r1forever80's Avatar
Op I pmed you back. It all depends on what you want. The early 03 that don't have hids can use the h1s. The later with hid to save on money can use the d2s morimotos. Only issue I don't like about the pnp projectors is that they aren't centered in the lower location. The morimoto projectors are ok but there are better.
Old Oct 19, 2012 | 07:27 PM
Replied to all the pms i got from this post lol
Old Oct 20, 2012 | 12:22 AM
Garage Kansai's Avatar
I did the quad set up on my sedan. Definently not a fun process.
Old Oct 23, 2012 | 10:13 PM
Mosheh1am's Avatar
Any one in the nyc interested in doing a quad retrofit for my sedan?
Jusseth
Sep 13, 2020 12:25 PM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
TheKnite
Aug 14, 2015 07:59 PM
chinee
Aug 8, 2015 10:11 AM
teamghost
Jul 28, 2015 04:52 PM
