Has anyone ripped off the cat heat shields? Negative consequences?
Old Oct 29, 2012 | 06:41 AM
Mustang5L5's Avatar
The rattling and buzzing is starting to annoy me. Right now, i use wire coat hangers to try to tighten them up, but seems like every couple of weeks i have to readjust.
I wanna rip the things off. Anyone done this? Any bad side effects other than maybe badly burning a cat if i run one over?
Old Oct 29, 2012 | 06:54 AM
04nismoG's Avatar
I have a 04 sedan and I took the driverside heat shield off because I had to change the motor mount and I didn't put it back on and its been well over a year now with no problems.
Old Oct 29, 2012 | 08:53 AM
Songle6MT's Avatar
Mine have been off for about a year and I haven't noticed anything negative from it.
Old Oct 29, 2012 | 10:44 AM
AzuMaster's Avatar
They are only on to prevent fires. If your cats get super hot like they usually do and you drive over dry leaves in a wooded area you can start a fire. So long as you're not offroading in the dry woodlands you should be fine.
Old Oct 30, 2012 | 05:29 AM
srv2nv's Avatar
G35 Sport
Took both mine to prevent rattling, and we ripped them off my friends Maxima. Both cars are still fine.
Old Oct 30, 2012 | 01:58 PM
geew1z's Avatar
Took mine off almost 2 years ago and other than a lack of rattling, no negative side effects..
Old Oct 30, 2012 | 08:53 PM
vizkat's Avatar
Ha! I did the exact same thing! Coat hanger wire. Still didn't work so I ripped those damn things off and ended up cutting my palm pretty good too. Anyway, no issues to date and I think it this past Spring.
Good to go. Just be careful cutting/pulling them out.
Old Oct 31, 2012 | 01:51 PM
togee's Avatar
Same here. Had them removed earlier this year. No problems whatsoever, but like the other poster said, best to stay away from dry leaves!
Old Oct 31, 2012 | 06:33 PM
butkiss1's Avatar
Do it ...ur good
Old Oct 31, 2012 | 07:45 PM
03GT35R's Avatar
I have removed every heat shield under my car, no issues....
Old Nov 2, 2012 | 11:30 AM
Sacch's Avatar
Can someone post pics or point on the location of the different heat shields under our car? I hear a lot of rattling. BTW I already ripped out the cat heat shields, no negative effects.
Old Nov 2, 2012 | 11:33 AM
PAIXAO's Avatar
I just used self tapping screws to secure mine. Thought about taking them off.....but I figured it was best to just secure them better.
Old Mar 20, 2013 | 10:57 AM
CMan425's Avatar
Ripped mine off my coupe due to rattling. It made the car growl bit louder, in a good way though, like you have an aftermarket intake. I just bought some exhaust heat wrap and wrapped up the same area to mitigate the heat and dry grass issue.
Old Mar 20, 2013 | 11:02 AM
Wi-Z_Sam's Avatar
Just take everything off...open it up from the headers back
Old Mar 21, 2013 | 01:50 AM
xsl_will's Avatar
Mine were off for quite some time. Then I got test pipes.
There are heat shields on the exhaust manifolds, around the cats, over the midpipe resonator area, and over the muffler area.
Picture Share
Feb 4, 2018 12:41 PM
DRG35R
Jan 31, 2016 07:14 AM
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
