04 G35x Wheel bearings !
Old Dec 19, 2012 | 11:03 PM
Reedtc's Avatar
Exclamation 04 G35x Wheel bearings !
I've been looking for some front awd bearings forever & I can't seem to find them . I was told you could not had regular sedan bearings but my searches return nothing , does anyone know where I could find these ?
Old Dec 19, 2012 | 11:10 PM
5150DS's Avatar
Rockauto or ebay
Old Dec 19, 2012 | 11:34 PM
Reedtc's Avatar
Originally Posted by 5150DS
Rockauto or ebay
Yes, I've seen one on rockauto for 89 but it states that its the wheel bearing only, but it kinda looks like the whole hub assembly.. Has anyone ever purchased this before ?
Old Dec 20, 2012 | 08:26 AM
Mustang5L5's Avatar
Yes, they are OEM manufactured bearings (NTN) distributed by Timken and are bearings only. You need to purchase the hub and press them together.
There was an ebay seller selling them together for a while.
Have a read.
https://g35driver.com/forums/brakes-...-bearings.html
EDIT:
Ebay link $199 + $18 S/H
http://www.ebay.com/itm/04-05-06-inf...267631&vxp=mtr
Old Dec 20, 2012 | 08:42 AM
ccc123pm's Avatar
X
the $89 is for the bearing only... As mustang said, the bearing will need to be pressed onto your existing hub.
Old Dec 20, 2012 | 08:47 AM
ccc123pm's Avatar
X
also, maybe another question for Mustang... I need to get my caliper brackets off but they are on there pretty good. Any suggestions on how to get the two bolts out?
Old Dec 20, 2012 | 09:29 AM
Mustang5L5's Avatar
22MM socket + breaker bar + pipe over the end.
If you turn the wheels to either side, you can get the clearance to put a little torque into the pipe.
If you have a 22mm wrench, put the closed end on the bolt, and then use another wrench with a little mass and hit the end of the wrench. You don't need to go crazy, but the act of quick, sharp impacts can usually break the bolt loose like an impact gun.
Usually when i need to break a bolt loose, i can suceed by using 2 wrenchs. One is the closed end over the bolt, and the other wrench to hit the wrench in the loosen direction.
I have never needed an impact gun using that method.
Old Dec 20, 2012 | 10:22 AM
Rich@GRUBBS's Avatar
PREMIUM SPONSOR
AWD G35 Sedan
40210-AL800 Front Wheel Bearing
Old Dec 20, 2012 | 11:14 AM
MikeDG's Avatar
Hey Phil, just out of curiosity, are you guys able to press the hub assembly and wheel bearings together? I'll be in the market for rear wheel bearings for my rwd sedan in the near future.
Old Dec 20, 2012 | 11:45 AM
PREMIUM SPONSOR
Thumbs up
Hey man, one of my techs can press them together,
Total for the pressed bearing
$313.00 shipped
Cajuncowboy
Jun 21, 2021 09:47 AM
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
wuppiedog
Aug 7, 2015 11:16 AM
rping
Jul 26, 2015 09:53 PM
