Odd Squeak Rear Deck area
Jan 21, 2013 | 07:10 PM
For the last few months I been getting this odd squeak coming from behind the driverseat. Happens most when I hit bumps around 60mph. Sounds like it coming from the rear deck. I padded the deck some, made sure rear seat are tight and I sprayed some parts under the deck in the trunk, but the squeak is still there. Anyone have this issue?
Reply 0
Jan 21, 2013 | 07:51 PM
Me too! I get this strange squeak/creak noise pulling in and out of my driveway. I replaced my rear shocks last weekend, and didn't notice anything loose or broken like a swaybar endlink so I haven't a clue either. Maybe my swaybar bushings need grease?
Reply 0
Jan 21, 2013 | 07:58 PM
Same here. I read somewhere that i need to grease the rear shock top hat and it should stop. Havent had the time to try though
Reply 0
Jan 21, 2013 | 09:51 PM
Yeah to me it sounds like its inside of the car in the deck but it could be the struts. Im spray them tonight and see. Are you too sound coming from the driverside too?
Reply 0
Jan 21, 2013 | 10:10 PM
I'm try this
https://g35driver.com/forums/g35-sed...abin-area.html
Reply 1
Jan 22, 2013 | 12:13 PM
Good find, I'll try that when it warms up outside!
Reply 0
Jan 22, 2013 | 06:28 PM
I had the same issue and the rear cross brace was the culprit. Here's a picture of what you're looking for.
Show more
Reply 1
Jan 22, 2013 | 07:42 PM
You're the man Blue Dream! Thanx for the pic - seriously, as soon as it warms up here in NJ I'll be pulling my back seat out to check those bolts. IMO that should have been welded in from the factory, not bolted in.
Reply 0
Jan 22, 2013 | 09:03 PM
Just add some locktight.
Im in DE its 19 degrees bruhhh
Reply 0
Jan 22, 2013 | 10:17 PM
Word, it's 16 here right now, wind chill makes it feel like 0. Too friggin' cold to be wrenching on the car, that's for sure! Once it gets back into the 40s I'll pull that seat out and check it.
Reply 0
Jan 23, 2013 | 12:23 AM
Yeah it was 78 today and its 52 right now...freakin cold weather.
Reply 0
Mar 2, 2013 | 08:01 PM
I locktight the brace but I still hear the sound. It's def. behind the driverside area in the rear.
Reply 0
