Car Accelerating by Itself After Cold Start?
Old 01-21-2013, 07:22 PM
LolMooses's Avatar
Whenever I start the car cold, it accelerates by itself when I get into gear (its a standard). To further clarify, it'll start with a high idle like it usually does in the cold. It has no problem getting down to 600-700 idle RPM's, but when I put it into gear and take off at a cold start, the car will just keep moving forward with no RPM drop when my foot is off the pedal. If I brake, the engine fights against my brakes and the engine surges when I put the clutch in. After 5 minutes it'll be absolutely fine though. It's really strange and I've been feeling a loss in power (but that could just be my paranoia) lately. Im thinking dirty TB?
Old 01-22-2013, 07:55 AM
Mustang5L5's Avatar
I notice this on mine too. Cold start just has a higher idle to warm the car up faster. Higher idle will try and push the car forward more.
However, hard to judge if yours is like mine...or far more excessive...without being there and seeing what it does firsthand.
Old 01-22-2013, 10:39 AM
Peoria35sedan's Avatar
Sounds like you need to let the car warm up longer, the Idle maps switch when the coolant gets to operating temp (80 deg C). There are a bunch of different idle settings when you look at the map, I haven't taken the time to see what all the variables are yet. Usually a dirty TB causes the car to stall not surge.
Old 01-22-2013, 01:38 PM
LolMooses's Avatar
Why would it fight against the brakes and as soon as I let off the clutch, the car jerks harshly and the RPM's shoot up?
Old 01-23-2013, 09:49 AM
AARONHL's Avatar
I notice this on my manual, I don't have to give the car any gas to rev-match on an up shift when switching gears while it's warming up..
Old 01-23-2013, 11:27 AM
LolMooses's Avatar
Is getting into second very difficult for you when it's really cold out? I find myself rolling to a stop because I can't shift its so god damn cold :/
Old 01-23-2013, 09:18 PM
AARONHL's Avatar
Yea, but you should change your tranny fluid with NISSAN MTF and you will sliiiiiiide right into second
Old 01-24-2013, 07:34 AM
LolMooses's Avatar
I did a fluid change with nissan MTF a few months ago. I think the synchros are going :/.
Old 01-24-2013, 11:07 AM
Wannabe6MT's Avatar
-MN G Crew-
My car does the same thing when its cold and its revving higher to warm its self up. I put that thing in first and she takes off down the street like it has a mind of its own. Hell I can get into second gear without ever needing to give it gas lol.
Old 01-25-2013, 04:29 PM
Tolboothwilley™'s Avatar
The car will attempt to stay at 1100-1200 rpms until it is past the batch fire. It will slow then go down as the temp rises.
Sounds like you need to extend your warm up time some
Hasanbaloch
02-29-2024 08:45 PM
chinee
04-19-2021 09:18 PM
NemesisGee
08-11-2015 07:10 PM
newg37
07-26-2015 09:32 AM
G35OUTLAW6MT
07-13-2015 02:26 PM
Quick Reply: Car Accelerating by Itself After Cold Start?
