2003 G35 Sedan: Missing Coolant - Overheating
Old Apr 20, 2013 | 08:01 PM
tite_tite's Avatar
Hi,
I have a 2003 G35 Sedan.
For the last 6 months, I have been filling coolant into my car. I would be doing a little coolant every 2-3 days. (i would say 3-5 shot glass..alcohol shot glass ...) If i drive the car hard, i would have to fill it once a day. Also, when i am stuck in traffic, temperature gauge would rise close to H but comes down & rise back & comes down. Temperature gauge will come down to normal when the car is moving. Coolant is missing when that happen. The only problem is I do not know where it is going.
I have check for bad gasket & it doesn't appear to be the problem. My car drives fine. I looked at all the hoses connected to the radiator & there doesn't appear to be a leak.
My guess right now is potential water pump, thermostat(doubt it), etc.
Any advice would be greatly appreciated. Thanks in advance.
Old Apr 20, 2013 | 09:30 PM
whatsnext's Avatar
Ive have a 03 coupe and had same problem had a crack in the plastic on radiator alot of people have had to replace there due to the plastic cracking. Do you get puddle under car or see any liquid on radiator?
Old Apr 20, 2013 | 11:26 PM
tite_tite's Avatar
no, there is no puddle
Old Apr 21, 2013 | 02:03 AM
whatsnext's Avatar
when my radiator crack i didnt have puddle under car either really cause takes a bit to build pressure i just noticed some dried radiator fluid on one spot on the radiator couldnt find the crack. have you filled it up and let it run till it warms up and builds pressure and try see if you see anything. ive heard off freeze plugs getting corrosive and leaking. But if your not seeing anything =( could be a head gasket.
Old May 19, 2013 | 12:57 AM
tite_tite's Avatar
Update..
Update..
Symptom: Coolant is missing (i would say 3-5 shot glass..alcohol shot glass ...) . I would need to fill every 2-3 days. If the car is idiling or in traffic, the coolant would drip more & temperature gauge goes close to the H but goes back to normal if the car is moving (no traffic or idiling)
I have not found out where the leaking is coming from until today when i replace my starter. So i am able to see the coolant in the spot but do not know where exactly the leak is coming from. Does anyone have any idea?
Radiator, Water Pump, or Radiator is eliminated since they are in the front & leak is coming from back of the engine.
Old May 20, 2013 | 11:11 AM
MikeDG's Avatar
Any pics of the area where you found the coolant?
Old May 20, 2013 | 08:55 PM
tite_tite's Avatar
Pics in the attachment
Attached Thumbnails 2003 G35 Sedan:  Missing Coolant - Overheating-leak.jpg   2003 G35 Sedan:  Missing Coolant - Overheating-leak-2.jpg   2003 G35 Sedan:  Missing Coolant - Overheating-leak-3.jpg
Old May 20, 2013 | 09:35 PM
Eric@TCGMiami's Avatar
looks like it could be leaking from the heater hose, if not it could be the hoses behind the engine... there's a fudge load of hoses on the engine towards the rear...
call me if anything perhaps i can help you more indepth...
I'm willing to bet your fan clutch is gone.
305 300 2984
Old May 20, 2013 | 11:33 PM
tite_tite's Avatar
305 300 2984
appreciate you leaving your contact info. i replaced the fan clutch when i first bought the car about 3-4 yrs ago.
heater hose is a possibility but when i was looking for the hose in the area when changing my starter, i could not see any hose that was wet or leaking. i probably do not know where the heater hose is located at. i know there are 2 but do not know the location.
thanks again.
Old Jun 5, 2013 | 04:54 PM
Odejc's Avatar
I have an 03 sedan with the SAME exact issue... Some mechanics told me that it could be from some gasket leading to the heater coil.
I went the cheap route (not recommended) and bout one of those "Stop Leak" bottles at Pep boys...and dumped it into the radiator...supposed to seal cracks, and leaks in gaskets. So far so good...my coolant level has stayed the same.
Old Jun 5, 2013 | 09:07 PM
remember those products are band aids not permanent fixes
Old Oct 19, 2013 | 01:03 AM
tite_tite's Avatar
Update..
ok. so i finally got fed up w/ refilling coolant on a daily basis because i ran into a few overheating session so i been refilling coolant on a daily basis as i drive my car.
i decided to take it to a mechanic. it turns out the leak was toward the back of the engine on a pipe. it was a bad gasket. i end up replacing the gasket & O ring & valve.
the part cost about $50 at the dealer but labor was $200. it has been 2-3 days & coolant level appears to be at normal level.
there was some hose that i wanted to replace but they didn't have it at dealer & needed to be ordered.
hope this will help someone. thanks again for all your input. good luck.
Old Oct 19, 2013 | 01:04 AM
tite_tite's Avatar
pics
Attached Thumbnails 2003 G35 Sedan:  Missing Coolant - Overheating-fix.jpg   2003 G35 Sedan:  Missing Coolant - Overheating-fix-2.jpg   2003 G35 Sedan:  Missing Coolant - Overheating-fix-3.jpg
Old Oct 19, 2013 | 04:28 AM
Awesome that it wasn't anything more serious !
Old Oct 27, 2013 | 10:08 PM
tite_tite's Avatar
Engine Diagram
Engine Diagram..
Good Luck..
Attached Thumbnails 2003 G35 Sedan:  Missing Coolant - Overheating-1.gif   2003 G35 Sedan:  Missing Coolant - Overheating-2.gif   2003 G35 Sedan:  Missing Coolant - Overheating-3.gif
TWASkyliner
Feb 8, 2020 08:00 PM
R350k5
Oct 1, 2015 08:41 PM
Rehman2009
Jul 27, 2015 03:23 AM
Chattzx
Jul 17, 2015 11:23 AM
