Fender pulling
Old Aug 10, 2013 | 08:23 AM
g35loving's Avatar
Fender pulling
Does anyone know how to easily pull the rear quarter on a g sedan? Ali pulled the fronts with my Eastwood very easy but the quarters are praising me off. Drivers side pulls pretty good but the passenger is not. Granted the passenger side has body work but was done right but it's like the roller is hitting the inner fender also with the lip of the quarter. Thinking about cutting it out some. What do you guys think?
Old Aug 29, 2013 | 04:09 PM
jkuo's Avatar
On the sedans, is there a bump in the fender lip? Where the corner of the door is? If there is, how are you working with it? I actually have an FX, but the rear door/quarter junction is pretty much the same as the G sedan. I've rolled the fenders flat, but there is a bump there that will not roll flat. I've even tried to flatten it with a hammer, but no good. So now the tires hit that bump.
Old Aug 31, 2013 | 08:03 PM
g35loving's Avatar
Do you have a picture of it? I have not heard or seen something that is a "bump".
Old Aug 31, 2013 | 08:14 PM
g35loving's Avatar
So I had to give up on the fender roller on the quarters. It just wasnt working. So I had to alot of metal working. Used my stud welder and also my hammer and dolly. I was able to pull it very well. I have to put some body filler in it but knew I would have to so was not a issue for me. Here are some pics
Old Aug 31, 2013 | 09:59 PM
jkuo's Avatar
Looks good.
Will try to find a pic. But right where the door curves and comes to a point. The quarter on the fx has some reinforcement. Didnt know if the g had that as well since the door line looks the same.
Old Sep 2, 2013 | 07:02 PM
g35loving's Avatar
Def get a pic. You may just need to cut the reinforcement out
Old Sep 2, 2013 | 11:14 PM
bluedevils95's Avatar
Not bad!!! How long it took you to do that
Old Sep 3, 2013 | 06:55 AM
g35loving's Avatar
The metal work took maybe 3 hours and smoothing everything out took about another 3 hours. It's time consuming but well worth it in the end
Old Sep 3, 2013 | 11:14 PM
AARONHL's Avatar
That's what up
Old Sep 5, 2013 | 12:06 PM
4DGS's Avatar
Nice! saw this on instagram, stoked to see it skimmed and sprayed.
Old Sep 6, 2013 | 06:11 PM
g35loving's Avatar
It's not sprayed yet. It's just plasti dipped for right now until I can finish it up tomorrow and prime it. Will paint both quarters sometime this month
Old Sep 25, 2013 | 11:44 AM
lowerd4lyfe's Avatar
Nice work!!
Dallsinghjr1
Sep 17, 2023 11:25 AM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
alexbenz
Sep 26, 2015 11:30 AM
