06 Sedan Headlight Wiring
Old Aug 13, 2013 | 01:56 PM
05_SkylineSedan's Avatar
20 Year Member
Weird symptom. FYI in '06 the low beams are HID bulbs in the upper portion of the headlight. The high beams are 1/2 of an H4 Halogen bulb (bottom of the lamp) and fogs are the other 1/2 of that halogen.
Here's the page which shows the wiring at the lamps (and a color chart). If you want to dig deeper grab the "lt" service manual here:
http://www.nicoclub.com/FSM/G35/Sedan/2006_G35_Sedan/
Attached Thumbnails 06 Sedan Headlight Wiring-lt-wires.jpg   06 Sedan Headlight Wiring-g35-wire-colors.jpg
Old Aug 13, 2013 | 02:28 PM
Mustang5L5's Avatar
2006 all have HID headlamps. Your's should too.
Look at the bottom corner of the headlights on the front lens. Does it say H1 or D2R on the lense?
Or are the bulbs so old they look yellowed like halogen lights?
Old Aug 13, 2013 | 05:13 PM
20 Year Member
OK, hopefully they just forgot to plug your HIDs back in, that would be the simple answer. And it would explain that you were seeing only fogs or high beams from the halogens. There are several fuses and relays involved too so if you find the plugs all in place you'll need to dig a bit further.
Old Aug 14, 2013 | 02:47 AM
20 Year Member
Sorry, it's very hard to read what's happening in the pics you've posted. Probably because it's not easy to get to the back of the headlights... Below is an illustration of the whole assembly from the service manual. Remember the Xenon bulb should be behind the upper cap and the lower position should have an H4 (double filament) halogen. (You've already said that was working - fogs and brights - so your H4s are wired correctly and only your HIDs aren't running). The ballast for the HID is supposed to be at the very bottom of the housing. The parts may all be there but just a plug isn't plugged or a fuse has popped. Before you go buy anything you need to figure out what's really happening. (Maybe a trip to the dealer for help, or back to the body shop?)
Old Aug 16, 2013 | 02:54 AM
20 Year Member
The wire colors don't seem to relate to what I posted above ('06 for sure?) so maybe the whole thing was modded. But the main thing is: if the lens is marked "D2R" then it was designed for a D2R bulb and an H1 would probably not put the filament in the exact right spot to focus your low-beams correctly. I'd even be concerned about heat issues with the physical difference between the two types of bulbs. I could be wrong about those points though, maybe they're more similar than I think.
I find it odd that anybody would purposely switch from HID to Halogen. Usually people are trying to go the other direction. Hopefully they didn't cut anything away or damage your lens to the point where a D2R won't fit any more. For instance, there aren't supposed to be any wires going through the upper "cap" like in your 3rd pic above so you're probably missing the HID plug and socket bits too. Getting back to stock could get costly unless you found a full used set or headlights somewhere with bulbs and ballasts.
But if you've got it to work as is, and the low beams aren't blinding oncoming traffic or anything, then I guess you're OK for the time being.
Old Aug 16, 2013 | 09:15 AM
Mustang5L5's Avatar
Originally Posted by 05_SkylineSedan
The wire colors don't seem to relate to what I posted above ('06 for sure?) so maybe the whole thing was modded. But the main thing is: if the lens is marked "D2R" then it was designed for a D2R bulb and an H1 would probably not put the filament in the exact right spot to focus your low-beams correctly. I'd even be concerned about heat issues with the physical difference between the two types of bulbs. I could be wrong about those points though, maybe they're more similar than I think..
Some bulbs do match up, some don't. Hit or mess on the brand since most rebased HID bulbs don't have any specs and therefore each manufacturer is free to do what they want.
D2R bulbs have specs, so each manufacturer much meet those specs to be accepted by OEM's.
Jusseth
Sep 13, 2020 12:25 PM
itgogitrev
Lights
May 2, 2016 06:53 AM
Twinturbo09
Lighting
Aug 3, 2015 11:06 PM
Thunderaan
Jul 22, 2015 07:40 PM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
